how do i verify that my car is a daytona 500 edition
Old Apr 4, 2008 | 05:06 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
How do I verify that my car is a 1983 25th Anniversary Daytona 500 edition and not a clone?
Old Apr 4, 2008 | 06:57 AM
90TA's Avatar
Re: how do i verify that my car is a daytona 500 edition
Post the info from the tag next to the hood release on the upper radiator support.
The person that did your appraisal should have been able to tell, but that is if they knew what they were doing (a rarity in today's world).
Old Apr 4, 2008 | 08:18 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Look for the Y82 RPO on the build plate on the radiator support.
There are also several DT500 specific items to look for. But the Y82 should be the easiest way to tell if it is real.
Old Apr 4, 2008 | 08:53 AM
90TA's Avatar
Originally Posted by TAdan
Look for the Y83 RPO on the build plate on the radiator support.
There are also several DT500 specific items to look for. But the Y83 should be the easiest way to tell if it is real.
Actually, it would be Y82, same as the 83 Mecham Edition.
It would also need to have 604. Not to mention the tag matching VIN.
Old Apr 4, 2008 | 09:57 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Originally Posted by 90TA
Actually, it would be Y82, same as the Recaro Edition.
Whoops... Your right, its Y82. Also look for AQ9 to indicate the Recaro seats.
Old Apr 4, 2008 | 02:25 PM
KITT1983's Avatar
what is the 604? ill have check it when it is out of the shop its going to be there for a week or two, all the parts for it are special order only which equals one week for the parts to arrive. another to intall them.
Old Apr 4, 2008 | 05:15 PM
90TA's Avatar
The "604" is the interior trim code unique only on the '83 Daytona Trans Am.
You would also have the unique exterior color codes 11L 11U 82M
Yes it would have the AQ9, even though for '83 AQ9 designates the Recaro and Lear Siegler seats.
Your Tag should look like:
D ??? 2FS87 N 2?????
604 11L 11U 82M E
AQ9 CC1
Y82 N09 D80
Old Apr 4, 2008 | 08:58 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
90TA,
I believe the Recaro TA was Y84
Old Apr 4, 2008 | 11:53 PM
90TA's Avatar
Originally Posted by 82FirebirdTA
90TA,
That is correct. Meant Mecham Edition instead of Recaro. Post corrected.
Old Apr 5, 2008 | 02:05 PM
Agent13's Avatar
Engine: LG4
Interesting. I didn't know the Mecham cars had an RPO. Thanks for the information!
Old Apr 14, 2008 | 10:52 AM
KITT1983's Avatar
i just check it at the shop today. it is a Daytona 500 edition
D018 2FS87N 2XXXX
604 11L 11U 82M E
AQ9 CC1
Y82 NO9 D80
054276 576308
Old Jun 30, 2008 | 07:09 PM
KITT1983's Avatar
how do i know what squence of production my car is out of 2500
Old Jun 30, 2008 | 09:43 PM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
No documentation on the build sequence numbers has come to light in my limited knowledge of these cars..................
Old Nov 16, 2009 | 06:32 PM
KITT1983's Avatar
simo what color is my interior plastic?
Old Nov 16, 2009 | 06:37 PM
simo's Avatar
Engine: CFI - 305
Light Sand Gray
Old Nov 18, 2009 | 06:36 AM
KITT1983's Avatar
Originally Posted by simo
Light Sand Gray
is the color of the door sil, quarter panel and trunk plastic?
Old Jul 2, 2012 | 01:53 AM
V8Broski's Avatar
Car: 1991 Camaro RS
1983 25th Anniversary? 25th what? Daytona 500?
Old Jul 2, 2012 | 06:09 AM
KITT1983's Avatar
thanks for reviving my dead thread
can you please restate your question?
Old Jul 2, 2012 | 06:16 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Yes. Daytona 500 25th anniversary.
Old Sep 25, 2012 | 10:06 PM
IROC4U89's Avatar
Engine: 5.7
Transmission: 700R4 shift kit w hurst dual gate
Well thank you for the great post. I just baught a 1983 Daytona 5 speed car and now just verified its real. thank you all!!!!
Old Sep 26, 2012 | 10:02 AM
KITT1983's Avatar
no problem
we need photos
Old Sep 26, 2012 | 12:02 PM
kymmee's Avatar
Not to hijack this thread but just had the 82 MSE at the TA Nats and after a lengthy discussion at the tech line, the car was put in the modified class (it was repainted to orig, the git kit is unistalled)because I was told the MSE had NO RPO code, so its considered one mod. I cant speak for an 83 Mecham but if anyone can comment on this (start a new thread) I would appreciate the input.
Old May 4, 2013 | 10:19 AM
IROC4U89's Avatar
Engine: 5.7
Barn fresh 83 Daytona TA with only 65 k and a five speed!
Attached Thumbnails how do i verify that my car is a daytona 500 edition-image.jpg
Old May 4, 2013 | 07:29 PM
KITT1983's Avatar
Awesome find
Old May 5, 2013 | 11:46 AM
IROC4U89's Avatar
Engine: 5.7
The car does have a locked engine. So I'm not sure what I'm going to do until I pull it apart. I paid 850 for the car.
Old May 5, 2013 | 07:34 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
id say you scored pretty well. Daytona 500 t/a's dont grow on trees lol.
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
