Numbers matching transmissions
Old May 27, 2010 | 07:47 PM
Drew's Avatar
From time to time someone asks how to verify an engine is original. I don't remember ever seeing it mentioned here, but transmissions are stamped with the serial number also. Today I went looking for the serial on the 700R4 in my 91 Formula. The service manuals show a few possible locations for ID stamps on the 700R4. There's a flat pad on the passengers side just above the inspection cover, and another further back above the pan rail. The one just above the rail had some stamps, identifying the build date of the 700R4. I found the serial number further back on the case, on the drivers side just in front of the tail housing. The 6 digit number matches the last 6 digits of the VIN on the car. I was kind of hoping the transmission wouldn't be original so I could easily justify the T56 swap... No such luck.
The T5 would have an ID tag on one of the main case to tail housing bolts, but the partial VIN should appear on the flat pad on the passengers side of the main case. The shop manual for 1991 shows an alternate location on the drivers side of the main case.
Old May 28, 2010 | 11:08 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: Numbers matching transmissions
interesting I never knew trannies where stamped with matching serial numbers I learn something new everyday
Old Oct 12, 2010 | 08:19 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Drew - are the serial numbers on a piece of the case that looks like a 3D rectangle casted into the case - and the numbers are running up and down, perpendicular to the ground?
Old Oct 12, 2010 | 08:39 PM
Drew's Avatar
Mine was vertical on the flange just in front of the tail housing.
Old Oct 13, 2010 | 06:42 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Get this,
When I rebuilt my transmission in 1998, there was no VIN, no stampings, no nothing, there was a place for it, but it was all blank...
I figured it had been replaced with a new trans as when I rebuilt it the innards were perfectly new looking. The previous owner only had it for 6K miles before he parked it. He got it off of a small dealership who got it from the first owner.
In 2007 I fried 3-4 and the trans guy made me a shift kit of his own design, more or less he said there was no performance parts in the trans it was the least performance trans that they made... He changed that.
MX0 was cast in the housing and that was it.
John
Old Oct 13, 2010 | 10:32 PM
puma1552's Avatar
Are rear axles stamped as well?
Numbers matching to me always meant engine/tranny/rear.
Old Oct 13, 2010 | 11:14 PM
Drew's Avatar
They're supposed to be stamped on the front of the passengers side axle tube... But I'm not sure if the car's serial number is stamped there, or how visible it'll be. Most rear axles weren't painted, they were left bare steel so they usually get pretty corroded. I've never been able to spot the code, but I usually don't bother to look for it either.
Old Oct 14, 2010 | 09:29 AM
okfoz's Avatar
No I do not believe that they were on the axle. My 1989 Convertible was really clean, it still had the original stickers and even a sticker that looked like a price tag sticker on it. There was no numbers that would reference the VIN that I found.
Old Oct 14, 2010 | 12:18 PM
Drew's Avatar
The book says there's a stamp or a tag on one of the bolts.. But all they tell you is manufacturer, build date, shift, etc... No mention of a serial number.
Linson
Oct 24, 2025 02:00 PM
apie2546
Oct 16, 2016 02:24 PM
rusty vango
Sep 29, 2015 02:44 PM
3.8TransAM
Sep 27, 2015 08:37 PM
tcflint
Sep 27, 2015 05:58 PM
