95-97 Firebird Cluster....
Old Jun 16, 2006 | 10:44 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
if anyone has a 95, 96, 97 firebird cluster let me know please.
Clint
Old Jun 16, 2006 | 11:42 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Clint
I have one out of a 1995 Formula with the 150 speedo $75
Old Jun 16, 2006 | 12:20 PM
Firebat's Avatar
I'll be getting rid of my 4th gen trans am cluster. I think its a 94-96. The trip odometer doesn't work, so I'll sell it cheap. I'm looking for a 97 t/a digital odometer equipped cluster in the meantime.
Old Jun 16, 2006 | 04:02 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
tpi-hearse and firebat..
does it have the connector on the back? i will need it
Old Jun 16, 2006 | 04:51 PM
tpi-hearse's Avatar
I have the complete car..so yes I could cut it out...
Old Jun 16, 2006 | 04:57 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
PM Sent
Old Jun 17, 2006 | 11:37 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ttt
Old Jun 17, 2006 | 12:33 PM
1trick67's Avatar
Car: 88 gta 67 camaro
Engine: 5.7 350
Transmission: 700r4 with shift kit muncie 4 sp
i have one out of a 96 ta i will sell for 50.00 shipped. it works great email me at leonardclok@comcast.net
Old Jun 17, 2006 | 08:54 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i also need the connector with a couple inches of wiring...
Old Jun 20, 2006 | 11:31 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
does anyone know if a 94 trans am cluster wit a V6 is worth using ? also said the glass is broke, can i take that off and put one from a 2000 camaro in its place?
please help ASAP
Old Jun 20, 2006 | 12:55 PM
Firebat's Avatar
The V6 cluster has a V6 tach, your tach will not display the right rpm.
Attached Thumbnails 95-97 Firebird Cluster....-01_1_b.jpg   95-97 Firebird Cluster....-guage2.jpg   95-97 Firebird Cluster....-e0_1.jpg
Old Jun 20, 2006 | 12:59 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok so i need a v8 one, thanks.
Old Jun 20, 2006 | 01:01 PM
Firebat's Avatar
best bet on the lense is to get a pic and see if it looks like the one from the camaro. Looks like the camaro had a few different lenses depending on the year
Old Jun 20, 2006 | 01:16 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
the lense on the 94-97 screw in, i have the one in the last pic from a 2000 LS1 it just clips on, i only needed one if i got that v6 cluster but im gonna pass
Old Jun 20, 2006 | 06:43 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
actually i have a question. can i use the connector on the back of the cluster ? are they different from v6 or v8 or are they all the same? if so i will grab the connector with wiring
its from 94 v6 firebird
please help ASAP i have a chance to get this now
Old Jun 20, 2006 | 08:21 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
actually i have a question. can i use the connector on the back of the cluster from v6? are they different from v6 or v8 or are they all the same? if same i will grab the connector with wiring, its from 94 v6
if anyone can help, i need to know by morning time...
Old Jun 21, 2006 | 07:19 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
common someone must know if the v6 and v8 connector wiring would be the same for the cluster from 94-97?
or did v6 and v8 have different wiring, please help need to know today so i can pick one up
Old Jun 21, 2006 | 01:59 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ttt
Old Jun 21, 2006 | 03:20 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
common guys just 1 answser and ill stop being a PITA
all i need to know is whether the wiring for the cluster between a v6 ad v8 is different in 1994-1997
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
