91 TA Steering Column
Car: 1991 Trans Am
Looking for complete steering column for 1991 trans am with vats. Needs cruise, tilt, and delay wipers. Needs to be in good condition. Shipping to zip code 62454. I would like to see pics too.
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Re: 91 TA Steering Column
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I have one out of a 92 Firebird. 5 spd car, cruise, tilt. Very tight comlumn. None of the typical GM column play.
Car: 1991 Trans Am
Mine is an automatic, not sure if the 5 spd will work. Any comments.... If it will work I would be interested.
Engine: 6.0 Vortech
Transmission: 4x4
I also have an 82-84 Firebird one with tilt and cruise. $150.00 Shipped in U.S.
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I have one from a 91 TA. You need 1 from a 89-92 firebird if you want it to be correct. Camaro columns are different.
Car: 91 Formula
89-92 had vats. 90-92 had airbags also. Do you want a airbag or non-airbag column?
Car: 1991 Trans Am
So I need a 90-92 Firebird airbag and vats column. My current column had airbag and vats.... Is also an automatic. Sounds like thats the only kind that will work. Thanks for the input.
Car: 91 Formula
I have a nice column from a 91 TA. The letters and the turn lever are nice, removed correctly with key and vats box. You won't need the vats box if you have a working vats key for car now. $20 a locksmith will make you a working vats key without changing the ign. cylinder.
or changing the vats box in the dash.
sjorgens
Oct 1, 2015 07:54 PM
