need heater box part
Old May 13, 2008 | 10:38 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i need the part the hot/cold lever control cable clips to on the heater box that controls the door, not sure if it's part of the door or not.
Old May 14, 2008 | 08:20 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: need heater box part
It looks like the clip retaining the cable and the cable will separate cleanly from the box, and it also appears that the metal pin / metal bracket are part of the door and therefore a part of the box assembly. You *Might* be able to use the same part from a regular AC box ?!?!? When I get my hands on an AC box I'll compare the bracket to the one on the Non-AC box and update this thread.............
I can't pull this little piece from my box for Ya',....... but wanted to post a picture so that people can see what you are looking for.
Hope this helps !!!!!
Old May 14, 2008 | 08:50 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
john, thanks thats the part i'm looking for, except mine is shaped differently, is that box from an 82-83? i looked at my brothers 83 and it looked like the pictured one, but mine is different, mine is an a/c box and so is my brothers 83
Old May 14, 2008 | 09:29 AM
John in RI's Avatar
YES - The Box WAS pulled form an 83 Camaro. That picture is from a NON AC Box, I JUST looked at 3 non-AC boxes they all looked like the bracket in my first post. I KNOW that one of the other boxes was from an 85 Bird but I don't know what year the 3rd box was.
I also looked at 4 AC style heater core boxes that have a brace that looks like this: ( they could be from any years between 85-92, I can't be sure ! )
After looking at tham I can say that - The brace IS a part of the door itself and it looks like your going to need to swap the door or the whole box if your bracket is busted.
I forgot there was any difference at all ! The Non AC style box always seems to be covered by an extra trim panel and the brace is not normally visible. I removed the plastic cover to take the pic of the Non AC style box ! ( at least non of the AC style cars I've had came with a plastic cover over the cable - That's a good "POLL" question !! )
Old May 14, 2008 | 01:22 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yes! that last pic is what i have, i may have to swap the whole door, i believe this can be done inside the car by removing the front cover.
john can you get a pic of the door inside the heater box with the cover removed? can you spare that part?
Old May 15, 2008 | 11:56 AM
John in RI's Avatar
I'm not sure Where-When-or How,............. But We'll get you fixed up !
Old Jun 23, 2008 | 07:56 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
My little lever is broken and would look exactly like the second picture, if it were still there. There's a bunch of yards around here with A/C thirdgens, but can you pull that whole box out with the door in it without removing the dash?
Old Jul 12, 2008 | 04:04 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have 83 parts including all the heater boxes and parts
lemme know
good luck
Old Aug 4, 2008 | 02:08 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Did anybody have any luck fixing this? I still have a stub sticking out on mine so I can turn it with pliers. I'm trying to think of a way to fabricate a lever.
Old Aug 4, 2008 | 04:57 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok so just replace the shaft ?
im confused as to why its so hard to figure out how to fix this one ?
good luck
Old Aug 4, 2008 | 06:43 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
good luck
Isn't the shaft part of the door, therefore the whole heater box has to be pulled out?
Old Jan 12, 2009 | 06:32 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I have the heaterbox for sale if someone needs it let me know and send me a pic of the whole thing so I know its the right one. Pm me I was going to throw it away a few days ago too (Crap I may have ill check)
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
1nastygta
Aug 8, 2015 07:38 PM
