Check engine light module
Car: 82 Firebird
Engine: 5.7 400hp Gto 350 block
Transmission: th350
Friend of mine in the uk is after one its mounted somewhere round the grey shaded area and plugs into the green plug, any ideas what it is and does anyone have one?
Cheers
Stu
Cheers
Stu
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Check engine light module
It's called a "Lamp Driver" and was used on all Cars originally equiped with a Carb motor. It accepts a signal from the ECM and relays it to the Check Engine light. When I convert TPI and MPFI cars to Computer Controlled Carb engines I always need to install on of these things between the ECM and the C/E light in order to get the C/E light to work correctly. ( when the original Fuel injected harness is used. )
The Lamp Driver is just a small circuit board that slides inside the green case.
Car: 82 Firebird
Transmission: th350
Thanks for the reply John, very informative
Does anyone have one of these lamp driver circuit boards?
Cheers
Stu
Cheers
Stu
It would be really expensive to ship anything oversees,... A 9 oz. package would cost $24US for Priority Mail ( 6-10 days ) or $10US for first class ( who knows when it will get there ! )
I've got one if you need it......... I cut the green housing with circuit board inside from a car today. $12 + shipping and it's yours if you still need it. If not, no biggie'. I don't find Carb cars in the bone yards much anymore and I'd be glad to have this one as a spare.
If your interested just send me a PM !
