91-92 Camaro Steering Column Tilt with vats and key
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I just got a 1991 Camaro with a 3.1 v6 auto. GOod shape going to pick it up next saturday. This car only has 98,000 miles on it. Not so sure on this since speedo does not work for the last couple of months.
SO I need a few things.
A good steering column tilt that is tight with vats box and key. The one on the column is jacked up.
A set of door keys hatch with good keys.
Re: 91-92 Camaro Steering Column Tilt with vats and key
I will get back with you after I pick the car up
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I have a column from a 91 Z28 with a key and the VATS box. You don't have to change the VATS box if yours is working and you have the key for the existing column.
I also have a full set of locks and keys from a 91 Formula.
BTW, 90-92 Camaro columns are the same.
