Electronic speedo and cable
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Im in need for an electronic speedometer and cable. I went from a mechanical auto tranny to a electronic 5 spd so i need to do a swap out of speedo gauges. let me know, thanks
Re: Electronic speedo and cable
Check the T-5 sticky for gear info. Here's the sleeve/ housing, which is the same as the TH350:
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
Just an FYI: 82-89 Camaros have mechanical speedos and the clusters have round gauges. Later Camaros, 90-92, are electric and have clusters that are half round. The two versions aren't interchangeable--at least not without serious modding.
JamesC
JamesC
Engine: Carb 355
Axle/Gears: 4.11
thats weird. cause i ran the casting numbers off the tranny and it shows up as an 85 305 tranny with an electric gear setup
Engine: Carb 355
Axle/Gears: 4.11
probally. wont a th350 piece work in the tranny? thats wat the website was saying
TMZIrocZ350
10-07-2015 12:09 PM
