[ND] Need a good steering column with key
Old Apr 4, 2009 | 09:13 AM
relic87239's Avatar
Car: 1988 Chevrolet Camaro
Engine: In the market
Axle/Gears: 2.77
I need a steering coulumn with with a key. i dont need a steering wheel but if there is one attached i might be interested.
thanks
Old Apr 4, 2009 | 09:59 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Re: Need a good steering column with key
thanks
year and auto or manual car?
Old Apr 4, 2009 | 10:59 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you also need to say if your column needs a reader for the resistor for the VATS.
Old Apr 4, 2009 | 02:14 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Camaro or Firebird?
I have a manual column from a 84 Z28 with only 37K. Very tight with tilt, cruise and delay. Even the writing on the lever looks like new. No steering wheel included.
If you are looking for a cheap column or on a tight budget, this is not the column for you.
Old Apr 5, 2009 | 01:44 PM
relic87239's Avatar
Axle/Gears: 2.77
The steering column is for an auto 88 camaro. So there is no vats. Whats the difference in a steering column for a manual and an auto?
Old Apr 5, 2009 | 02:28 PM
Dokken10's Avatar
Car: 91 Formula
Manuals had a key release on the column. Most of the 80's had a lever that is on the L/H side of the column. Sometime in the late 80's GM deleted that lever and put a button on the ignition cylinder. Manuals did not have a nuetral safety switch but you could use yours and mount it to a manual column, I believe.
Old Apr 7, 2009 | 04:41 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Steering column with key from non vats z28, $60 shipped.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
