power seat wire harness
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
I'm looking for the wire harness that runs from the fuse box to the drivers seat.
I understand that there are a few different types. the one I need doesn't tie into the passenger seat and the plug on the seat has two connections one ground and one hot.
also if anyone knows what size fuse I'll need that would be cool if you could let me know
Engine: 350 tpi
Axle/Gears: ???
Re: power seat wire harness
could i get a pic of the part that plugs into the seat, there's a few different harnesses.
matthewcantin@comcast.net
Car: 87' Pont GTA
Engine: 5.7L
I also have some! They run $10.00 plus shipping and handling. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas R. ***
(805) 522-2539
www.houseofcamaro.com
Thank you,
Thomas R. ***
(805) 522-2539
Engine: 350 tpi
Axle/Gears: ???
thomas, I sent you an email yesterday to the aol account with some pics attached. let me know if you got it.
Car: 87' Pont GTA
Engine: 5.7L
Dear MattyC,
Sorry, but I never recieved your E-mail. My E-mail Address is TomAtTrc@aol.com. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas R. ***
(805) 522-2539
Thank you,
Thomas R. ***
(805) 522-2539
Car: 1990
Axle/Gears: stock
it isn't really a harness - its two wires - orange and black. the black goes into the ground - use the one that is on the center console.
the orange i ran from the seat to the 30 amp fuse off the fuse box. i split the wire, made a 3 wire connector and it works fine. i put in 2004 ta leather seats in and use the factory harness to connect to two front seats.
Car: 1990
Axle/Gears: stock
Thank you,
Thomas R. ***
(805) 522-2539
Thank you,
Thomas R. ***
(805) 522-2539
Car: 1987 + 1988 Trans Am GTA
Engine: 5.7 TPI L98 & 5.0 TPI LB9
Transmission: auto / standard
Axle/Gears: 9bolt BW, 3.27 PBR & 3.45
After taking a few GTAs apart I found out following:
Only in early 1987 the inflatable lumbar harness was a plug in harness. Starting in very late 1987 and 1988/89 the harness was part of the interior harness, can't tell about 90-92 GTA/TA but I guess that didn't change.
There's also a fuse panel under the dash (somewhere inbetween the radio and the steering column) with fuses only for the seats and the remote steering wheel/radio... None of my 1987s had that fuse panel there.
Good luck...
Good luck...
Ok, I screwed that one up - I just figured you're talking about Camaro seats, so disregard my last post...
