[OH] 1991 Firebird T5 Prom AXXD
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
Hey everyone,
I'm doing a conversion to 5 speed.
Looking for PROM code AXXD
Thanks in advance,
Shawn
937-205-8475
Thanks in advance,
Shawn
937-205-8475
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Re: 1991 Firebird T5 Shift Plate & Prom AXXD
I have a shifter plate from a 91 bird. I can track it down and take pictures if you are still needing one. $75+ shipping.
PM Sent.
I still need that computer off a 305 TPI w/ 5 speed. Code AXXD on the chip.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have a 730 ecm if your looking for that, whats wrong with your old memcal? If it was a automatic bcc axxb or something it will work fine.
I'm looking for parts needed to complete my 5 speed conversion.
Looking at the charts on this website, it appears the chip from the factory was code AXXD. That's what will match up with what I have after the conversion.
I've read on here about people having idle problems or the car wanting to die when the clutch is pressed when they use automatic chip on a 5 speed.
Just want to start looking now, cause I know it can take a while to find these parts. Hoping to change the chip so I don't have to worry about potential issues.
Thanks,
Shawn
Thanks,
Shawn
Engine: Lb9
Transmission: M20
that would be cause if the wrong vss was used or was left disconnected. you can always use a piggyback adapter like moates.net g1 and install a burned copy of the axxd. the ecm will still need the 4k ppm vss signal.
tyeo098
Nov 30, 2015 06:27 PM
