86 camaro harness
Old May 15, 2018 | 06:21 PM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
86 camaro harness
I need some under hood harness for my 86 Camaro z28. I'm not certain but it seems that it needs to be an 86 z28 no a/c 305 carb auto 700r4 car. the specific harness I need goes from the bulkhead by the brake master and runs across the firewall past the heater box into the passenger fender through the kick panel and terminates at the computer behind the glove box. it also contains the 4 pin connector for the trans that runs down the tunnel and possibly some other parts.
Old May 15, 2018 | 11:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 86 camaro harness
It sounds like you need the ECM harness ??? ( The ECM harness plugs into the ECM and the tranny )
I'm asking because the ENGINE harness is a separate harness. The ENGINE harness and the HeadLight harnesses plug into the firewall next to the brake booster on the drivers side.
Just want to be sure before I go digging to try to find one. Do you need the ECM too ??
michael
17
Jun 25, 2015 08:36 PM
tazz08
Jun 27, 2008 05:01 PM
porkyzilla
Sep 16, 2005 07:54 PM
ausrs
Sep 20, 2000 12:50 AM
