88' Camaro Cig Lighter Wanted
Car: 1988 IROC Z Camaro
Hi,
My cig lighter socket is broken, keeps blowing the ACC fuse. I need a new one if anyone has one contact me! The part I'm looking for is the silver metal piece in the pictures.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88' Camaro Cig Lighter Wanted
https://m.ebay.com/itm/gm-chevrolet-...8AAOSwZJBYAEKj
According to Brock’s part numbers this should be what you need
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
That one seems too short Brian, ( looks like the one in my 95Z) so it might fit OK, but will probably not accept a factory lighter......
I'll look around later tonight to see if I've got a decent stock / used one somewhere and will re-post once I can check into it.
FYI: This same Lighter/Housing/assembly ( whatever ! ) was also used in the 80's S10 & Blazer.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I have a few clean tested good ones with good lighter inserts as well if nothing else works out. Get me an email address for pics and other info
Henry
Henry
Engine: Lb9
Transmission: M20
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i also have a few. possibly the lighter as well
82 Iron Duke
Sep 26, 2006 09:51 PM
