DASH ?s
Old Jul 29, 2006 | 11:36 AM
djbcrazy7's Avatar
Car: 95ta
Engine: 350lt1
Transmission: t56
Axle/Gears: 410
DASH ?s
is there anyway to install a newer cluster out of a 91 or 92 in an 89?? if so how
Old Jul 29, 2006 | 02:02 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
If you want to use the cluster you will have to replace then entire dash. They are completely diffrent. Only thing you can use from your 89 is the dash pad.Plus you would have to change the wiring to the guages.......jt
Old Jul 29, 2006 | 11:22 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
jtmiller92 is correct.
Also, I'm moving this to Body and Interior board.
Thanks.
Old Aug 2, 2006 | 12:52 AM
ineeedmorespeed's Avatar
Car: '01 Lincoln LS - '89 Camaro Z28
Engine: 350 c.i. 1 piece seal truck block
Axle/Gears: stock 2.73 gears stage II
Thanks.
You moved it to the wrong board...lol...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
