How to Remove the Shifter Handle?
Old Aug 2, 2006 | 11:55 AM
poopapooman's Avatar
On Probation
Car: 1992 Pontaic Firebird
Engine: 3.1L
Transmission: auto
Axle/Gears: 4 spd
i have a problem here. me and my freind were trying to put a new shifter plate in my 92 firebird automatic and couldnt get the shifter handle off. he told me that most handle will just unscrew. i think this is wrong, b/c i think i just stripped it. now i can turnn it 360 degrees both ways and cant get in gear. its not a problem if its broken i know where another one is but i need to be able to drive my car. does anyone know how to fix or take off the handle so i can at least drive. Do i need to cut it open?
Old Aug 2, 2006 | 12:15 PM
j dezzy's Avatar
Car: 87 TA
is it an automatic or manual? manual I'm assuming...
Old Aug 2, 2006 | 12:21 PM
On Probation
Engine: 3.1L
Transmission: auto
Axle/Gears: 4 spd
nope sorry its auto.
Old Aug 2, 2006 | 12:24 PM
j dezzy's Avatar
Car: 87 TA
there is a little c clip in the back of the shifter handle you can pull out with a pair of small needle nose pliars. after that the handle lifts right off. be careful not to brake the plastic rod in the shaft...that's what presses down and releases the shifter to move...sounds like you may have broken it already. if so go pick one up at the yard for a few bucks. only manual handles are threaded. automatics always have the c clip.
Old Aug 2, 2006 | 12:48 PM
On Probation
Engine: 3.1L
Transmission: auto
Axle/Gears: 4 spd
thanks for the info. i tooke the handdle off. but do i need to replace the handle or the shaft or both?
Old Aug 2, 2006 | 01:10 PM
j dezzy's Avatar
Car: 87 TA
doubt that the shaft is broke at all. if it's not going into gear the problem is most likely with the handle or the plastic piece that goes in the handle. if the plastic piece is ok then it's gotta be the handle.
Old Aug 2, 2006 | 01:27 PM
On Probation
Engine: 3.1L
Transmission: auto
Axle/Gears: 4 spd
should the plastic be able to push down to put it into gear?. i can do it with my finger underneath but i can push the little *** down
Old Aug 2, 2006 | 01:35 PM
j dezzy's Avatar
Car: 87 TA
yeah. with the plastic rod in the shaft you should be able to push it down to change gears.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
