Roof console help ?
Old Aug 9, 2006 | 11:11 PM
yogi492's Avatar
Car: 86 Z28
Transmission: 5 speed
Roof console help ?
I'm installing a roof console that is a t-top type and I went to the tech page and found the instructions on how to do it Great but still have ? the two holes for the mounting screws that are 2.5 in. long and 1.5in. wide how far over do I have to put them from side to side??the print does not tell you how far over from end to end
Old Aug 10, 2006 | 12:50 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
there should allready be holes for them on the car. my 1988GTA had the holes allready there, and roof consoles were not available after 87. stands to reason that all cars should have them.
Old Aug 10, 2006 | 05:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sorry, I'm a bit thickheaded this morning, so I'm not sure what you're asking. Shouldn't you be able to measure the holes in the console itself?
X is correct, however. The holes should already be in place. I assume you're putting a t-top console in a t-top car.
Oh, I see. You're cutting the headliner. Put the console rightside up on a piece of cardboard and make a template: mark all the holes to include the ones in the dome light. Mock the template up using the screw holes in the dome light. Once that's done, you'll have a precise idea of where to cut (and cut little by little). With holes cut in the headliner, the mounting holes will be apparent. Worked for me.
JamesC
Lbibb
May 5, 2016 12:00 AM
LC2 TECH
Oct 13, 2015 11:53 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
ndndndnd
Sep 28, 2015 08:00 AM
