A good carpet dye.
Old Aug 11, 2006 | 02:29 PM
cdoyle's Avatar
A good carpet dye.
Hi,
The carpet in mine is in pretty good shape, but it's just started to fade pretty bad.
I would like to try and dye it, and make it look new again.
What is a good quality dye to use? I'm looking for a dark blue dye, and just don't know where to get it.
I've tried the duplicolor spray dye before, and I just didn't think it really lasted all that long. Seemed to wear off pretty quick, so was hoping there was something else that others have had pretty good luck with. That's doesn't cost a fortune.
Chris.
Old Aug 12, 2006 | 09:15 AM
cdoyle's Avatar
Anyone?
Old Aug 12, 2006 | 10:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The spray bomb dyes seemed pretty promising, I haven't used one yet... Did it rub off from wear?
Do you have a compressor to spray a dye in? You might have to steam clean it really well first, then use a dye that's not in a spray bomb... Usually a better quality...
I'm surprised no one knows more about this here , guess everyone just buys new carpet?
Old Aug 14, 2006 | 07:19 PM
cdoyle's Avatar
Ya I guess they all do?
My carpet is in good shape, just faded from the sun.
Was hoping others on here have already dyed theirs before and maybe had some suggestions on what to use.
Old Aug 15, 2006 | 05:40 PM
ihnsane's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Transmission: A4
I tryed to dye my carpet (red to black), but for some reason it just wouldnt soak up the dye, so I went to walmart and bought replacement carpet.
something like $8 for a roll, I got 2 of them and redid from the pedals to about the middle of the backseats. It was fairly easy and pretty fun. I also painted the door panels, arm rests, plastic parts.
Here is the original interior when I bought the car, and what I have done so far. Still need to do the kickpanels, paint the vents and some other minor things.
I am buying more carpet soon and doing the hatch area aswell.
Old Aug 15, 2006 | 08:59 PM
ajhagerman's Avatar
I worked for a large aftermarket company and we tested many systems and found DyePro to be the best.
Hopefully that helps
lee01
Apr 9, 2016 01:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MORREALE5
Sep 13, 2015 09:16 PM
