Door Locks in place of AC
Old Aug 26, 2006 | 12:57 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
MY 87 TA didnt come with power locks. IM going to have them installed but I want to put these switches in place of the AC to control the locks. All the AC was removed b/c i removed the pc to go carbed. What do you think and is it possible. Also what are thoughts like on a fiberglass center console all the way up to the AC unit as 1 piece.
Old Aug 26, 2006 | 10:24 AM
thondor's Avatar
Car: 92 RS T-Top
Engine: 5.0
1992 Chevrolet Camaro - Paul's Chevrolet "Thondor's Ride"
still not complete
Old Aug 26, 2006 | 11:31 AM
kelham's Avatar
Very NIce center console
What is the final covering on the top pic"the white one"
Looks like plaster or something....
Looks great, what did you use as a template "wood or plastic"
Kelham
Old Aug 26, 2006 | 11:32 AM
kelham's Avatar
also how are you bolting it in, stock areas
Old Aug 26, 2006 | 11:46 AM
thondor's Avatar
Car: 92 RS T-Top
Engine: 5.0
the white is masking tape covered with fiberglass and then removed right pic
still have to sand bondo and paint. covered ashtray lighted drive, reverse lighted slot. rounded into a/c control and radio. going to have stainless plate for more switch (Door pops high beams etc.) where window switches are now. have to make a new arm rest. going to just snap back in place. i covered first with a hardboard to raise it up for rounded edges. i just put some more pix up at my car domian site check them out
Old Aug 26, 2006 | 09:52 PM
kelham's Avatar
so u used the stock center console and then removed the fiberglass from it when it was dry..?
The black bezel around the ac and stereo did u leave that in fiberglasss or remove it once done.?
Im really interested in this but have no clue where to start with it...
I would like to make the whole thing from wood then fiberglass over it or would u recomend the way u did it better.
Old Aug 26, 2006 | 10:12 PM
thondor's Avatar
Car: 92 RS T-Top
Engine: 5.0
left bezel in it
then i covered it with hard board to raise the surface so i can have rounded edges
where i messed up was i used fiberglass cloth instead of fiberglass mat. never done this before. the cloth is too stiff and wouldnt wrap very well, kept popping back up. got real pissed, then i got some mat after some research on here and it went right on. wrapped well around the curves. i am just dreading the sanding part.
Old Aug 26, 2006 | 10:15 PM
thondor's Avatar
Car: 92 RS T-Top
Engine: 5.0
after it was dry u pop it off. next i need to sand it smooth bondo and sand and then paint. then just put it back on again over the stock console. should snap right back into place i hope
Old Aug 26, 2006 | 10:18 PM
thondor's Avatar
Car: 92 RS T-Top
Engine: 5.0
i actually put my stereo mount in there too make sure u cover everything well.if u dont the resin will soak through and will stick. layer of tape then a layer of foil then more tape.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
