A pillar "rubbers"
Old Sep 3, 2006 | 10:57 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
A pillar "rubbers"
Anybody know where to get the rubber part for the A pillar?
Old Sep 4, 2006 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
To my knowledge, these aren't sold separately. I stripped mine from the pillar, soaked them a few times with silicone spray to keep them from dry rotting, then reglued them. So far so good.
JamesC
Old Sep 30, 2006 | 09:27 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
get some thick foam weatherstripping for doors at home depot or lowes. if you look hard you can find it in black, and it matches factory near perfect once installed. you gotta look, most of the stuff is greyish brown and looks goofy when the sun hits it(or a camera flash) i guess you could paint it, but look for the rubber seal, not the foam seal. all the rubber seals should be black.
good luck!
Old Oct 3, 2006 | 08:31 PM
AC's Avatar
AC
Car: Used to drive a camaro
**Never mind** I was thinking of the front corner triangle that is right above/along side of the side view mirrors.
Kris, I replaced mine like 8 years ago and bought them from a GM parts dealer. I think now most 3rd gen parts are out of stock or discontinued. You could trie GM parts direct or e*ay. I think I paid like 30-40 bux for both when I bought them.
Last edited by AC; Oct 3, 2006 at 08:32 PM. Reason: Realized I was thinking of wrong part
Old Oct 3, 2006 | 08:55 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
paddock has the window triangle seals.
Old Oct 3, 2006 | 09:56 PM
krisb410's Avatar
AC, any chance you have a part #?
Old Oct 3, 2006 | 10:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
n/m
Old Oct 3, 2006 | 10:40 PM
krisb410's Avatar
Originally Posted by deadbird
GM
20598022 RH
20598023 LH
About $50-$60 a pop for OEM.
Thanks, I work at a chevy dealer, I'll check them out
91 zeee
Interior Parts Wanted
Sep 24, 2015 03:09 PM
aharvel50
Sep 21, 2015 07:31 PM
Fox118
Sep 12, 2015 09:29 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
