4thgen dashpad question
Old Sep 10, 2006 | 01:09 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have a firebird dash in my 86 from a 1993 i think. I used a dash padtop from a 2001 camaro. I have problems with the velcro poping up in the heat anyone have this problem? Also the 2001 pad dosent seem to fit as flush to the seams as I would like.
Old Sep 10, 2006 | 02:50 PM
Firebat's Avatar
Try looking for some better velcro. If the "sticker" part keeps on coming off, glue it down with 5 minute exoxy from Walmart. That epoxy is great.
My top 4th gen dashpad hasn't showed up in the mail yet so i dont know
Old Sep 30, 2006 | 09:13 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
was the dashpad really tight when you installed it?
mine popped up a few times and i went back and cut some off the windshield area and its fitting good now.
another tip is to open up the arm on the metal clips. after several times of use, they bend in. only problem with this is its harder to get the dashpad back off when you need to.
good luck.
Old Sep 30, 2006 | 01:15 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Stage20 is right about trimming it some. Mine was doing that when I realized I didn't cut enough off. This was enough to keep the pad from laying flat and when you push it down to snap it closed it was bowing it.
Also the pads from 93 to 97 are different from 98 to 02. I found that out when the junkyard one I got was like you said. The new one I bought for a 2002 fit perfect.
Old Sep 30, 2006 | 01:36 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
firebird ones are all the same 93-02 ?
Old Oct 1, 2006 | 08:28 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
All I know is that camaros and firebirds were the same from 98 to 02. 93 to 97 camaros are very similar but don't fit good at the corners.
Old Oct 9, 2006 | 11:06 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
no, i went through this problem...
the lt1 style IS different from the LS1 style...
the 93-96 have a point on the "corner" thats next to the defroster vent
the 97-02 style is rounded next to the defroster vent
Old Oct 9, 2006 | 11:47 PM
Firebat's Avatar
Would the top dashboard from a 97-02 firebird work in a 93-96 firebird dash, in a thirdgen?
Old Oct 10, 2006 | 06:25 AM
Car: 91 formula
Transmission: t5
no, thats the issue i came across, when i got it they didnt go together... beacuse of that corner
so i got a ls1 style top dash pad laying around and nothing i can use it for...
Old Oct 10, 2006 | 05:55 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thats what im thinking, doesnt it all get cut off anyway?
Old Oct 10, 2006 | 06:13 PM
Car: 91 formula
Transmission: t5
no
Attached Thumbnails 4thgen dashpad question-ls1dash.jpg   4thgen dashpad question-lt1dash.jpg
Old Oct 10, 2006 | 07:16 PM
Firebat's Avatar
Do you think the 97-02 dashtop can be modified to fit the 93-96 dash? With a cutting tool?
Old Oct 10, 2006 | 08:57 PM
Car: 91 formula
Transmission: t5
it will look like crap.... why not do it the right way and not have it hacked ?
Old Oct 29, 2006 | 04:49 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Hey guys the problem turned out to be that I had a screw in that mount to the drivers side that shouldewnt be mounted at all. I took the screw out and it now sits flat.. but still its from a 2001 ish camaro and I have a 94-96 t/a dash so im going to get the right pad. Thanks for the help!
Frozer!!!
Jan 19, 2024 04:55 PM
Linson
Nov 12, 2015 08:09 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
