new door latch review
Old Sep 14, 2006 | 06:09 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
my door is in bad shape overall,
i started with buying a new latch caz
i have to really bang on the door to shut it.
I bought a new latch for my pass side,
replaced them and now the door latches all the way very smoothly!
no more rattling noise either becaz my rubber piece was totally shot,
but now its all quiet.
i still have rattle from door hinge.. but the replacement was totally worth my money, was only 80$ and i dont have to tell my g/f or friends to bang on the door when shutting doors
Old Sep 14, 2006 | 06:59 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
i would fix the hinges next cause that could be why the latches broke
same thing happened on my iroc the doors sagged so bad you had to pick up to shut them. wasn't long the drivers side latch went out . did the latch & hinge pins no more problems .
Old Sep 14, 2006 | 11:30 PM
sogabe's Avatar
Engine: 3.1L
yeah the hinge is next on my list..
but i dont have tools and time to do hinge jobs.
how much of a pay should i expect if i take my car
to a body shop for hinge repair?(the one sold on top-down solution)
Old Sep 15, 2006 | 12:18 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
I heard its about a 2 hour job for each door, but Im not sure...
Old Sep 15, 2006 | 01:02 AM
sogabe's Avatar
Engine: 3.1L
2hrs is less than I expected though..considering
i hear story of taking pretty much whole day if u do it urself.
the rattle IS annoying me plus i dont wanna screw my new latch,
so its def my next thing to do
Old Sep 15, 2006 | 06:29 AM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
How big of a job was the latch install? Where'd you buy the new latch?
Old Sep 16, 2006 | 01:25 AM
sogabe's Avatar
Engine: 3.1L
it was actually hard to find online.
i think u might be able to buy if off dealer,
but Im quiet sure its cheaper in this site.
Milea Pontiac Buick GMC Subaru Daewoo
the job was simple.. but u do need the door panels off.
I read somewhere that while replacement the window had to be all the way down, so I followed that too. (not sure of the consequences if u dont)
instructions: take door panels off gently, try not to break panel clips and stuff.. u need the arm rest and console peace off, but those are just bolts off and snap off.
unbolt the 3bolts on side of the door(where it latches)
unscrew all that, but maybe leave 1 off to prevent drop offs.
what i did next was observe the latch a bit,
u'll see 3rods attaching to the latch,
memorize or label which rods goes into each place,
then take the rod off from the old latch.
Plastic peaces holds the rod into place, so use flathead and turn them around so rod goes freely.
take all rods off
now put the new latch in place like how it was,
connect all the rods where it supposed to be, and u r DONE!
seriously, very easy, took me 30min
not knowing what the hell to do at all,
so should take u way less. this was my 1st time taking my door panel off too.. so u get the idea. was worth my time and money for sure
Old Sep 17, 2006 | 04:56 PM
Car: 92rs
Transmission: 350
it has been a few years since i did my hinges and it took us most of the day to do both doors but my hinge was so worn out we had to search hardware store for bigger bushings , then use the ones in the repair kit.not many tools involved ,hammer ,chisels , punch , cant think of what else but most is basic stuff.hard part is getting the old pins out , and getting the spring on the bottom hinge back in place ( very stiff ) but we got it (dont remember how ). do a search on hinge repair , guarantee there is lots of info on it on here . good luck
also i got my latch from the dealer for 60 some bucks few years back .
Veaceonee
Sep 29, 2016 08:15 PM
PurelyPMD
May 5, 2016 04:57 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
3rdgenkindagal
Sep 29, 2015 01:41 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
