Electric Trunk Hatch Not Working, No Key...
Old Sep 16, 2006 | 05:58 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok here is the issue. I switched to 4th gen interior and now my trunk wont pop, i am replacing the whole interior plus the hatch area so i need to get the trunk open. I don't have the key for the trunk, but the electric hatch always popped. I SWITCHED to 4th gen interior so all wiring is re-wired. I THOUGHT i had the right wires orange, black/white wires but all i get is a buzzing noise coming from the passenger side area. So obviously i messed up, so i traced wires to the trunk.
I took apart all the sail panels and everything from the rear and see wires coming from behind the plastic piece covering the motor n stuff, there is orange(i see orange/white for a light in the middle), black, red/white, yellow, and a couple i tried all of them with the black wire and still no pop.
Someone help i need my trunk open how can i get it open!
Old Sep 30, 2006 | 09:06 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
sounds like the buzzing is a bad relay.
if you tap it a few times fast, most of the time it will pop.
if not, run some wires to an area past the relay and just tap the wires on a battery.
its gotta pop then.
Old Sep 30, 2006 | 11:33 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
found out it was the fuse, could have sworn i checked it
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
