interior steering colum
Old Sep 20, 2006 | 05:09 PM
gta31's Avatar
Car: 87 gta
Engine: l98
the inside steering colum broke on a panic stop when someone cut me off what can i do to repair this now the wheel still works and turn signals but the high beams making a popping noise when its pulled back but the whole colum moves around when i am driving making difficult
Old Sep 21, 2006 | 06:43 AM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
Transmission: one that dont work so well
are the bolts under the dash still tight they hold the colum up
Old Sep 21, 2006 | 12:07 PM
gta31's Avatar
Car: 87 gta
Engine: l98
tight enough to hold it still if nothing is touching it but if i go to turn the whole colum moves in the direction that i am turning because of the pressure on the wheel
Old Sep 22, 2006 | 07:09 AM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
ill have to look at the linkage and stuff on my car tomarrow to see what might be loose ill get back to you
Old Sep 24, 2006 | 12:17 AM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
i had to work today so i didnt have a chance to look will tomarrow or did you fix your problem yet
Old Sep 25, 2006 | 04:59 PM
gta31's Avatar
Car: 87 gta
Engine: l98
still looking for any ideas i looking at the bolts but it doesnt make sense why high beams still make clicking noise and wont come on
Old Sep 25, 2006 | 05:39 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
ok for the high beem thing there is a switch under the colom d-side if the rod poped out of it, it could be getting hung up on something. if it is still in tack it could be a bad switch of a wireing thing. Now for the collom thing it sounds like the bolts under the presser plate are loose, What you are going to need to do to fix this is get a steering wheel puller and a ring plate or o-ring deperser. IF you have a autozone or parts place like that you can rent these for free. after pulling that off you will see the bolts that are loose. IF there is cracked of broking metal in the you might need a new collom if so my friend is selling one. I hope this will help you.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
