Headliner install?
Old Sep 25, 2006 | 06:27 PM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
Headliner install?
is there a tech article on this?
Old Sep 26, 2006 | 07:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Replacing a headliner is pretty easy. It's basically just held in place by the components around it. You remove everything that's in the headliner's way, then it comes right down. This includes sail panels, the retainer around the seat belt, a-pillars, sun visors and dome light/overhead console. There are also 3 clips holding it in place at the top of the windshield that you'll need to pull out.
The new one goes in the same way, but without those clips near the windshield.
Old Sep 26, 2006 | 08:51 AM
Mr.Wolf's Avatar
Car: 87 Z28
does the same go for the second gen headliners?
Old Sep 26, 2006 | 02:35 PM
Jim85IROC's Avatar
I have no idea, I never installed one.
If I recall, some 2nd gens had the rod-style headliners that were held up with steel rods that the fabric looped around, but the later ones may have used the more modern style fiberglass/cardboard with the foam glued to it. That later style I would expect to install in a similar manner to the thirdgens.
Old Oct 24, 2006 | 03:29 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Is this for a T-top or hardtop?
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
