question on interior plastics
Old Sep 28, 2006 | 05:27 PM
cdoyle's Avatar
I have an 84 and want to get new interior plastics in a different color.
Are there any differences in plastic panels for hardtop and T-Top?
Any differences in the years, that I would want to avoid?
thanks
Chris.
Old Sep 29, 2006 | 05:54 PM
cdoyle's Avatar
I guess they are all the same?
Old Sep 29, 2006 | 06:36 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
All plastics should fit, the only difference you would encounter is the rear panel which will have the holes for the t-top bag. The lower door sills are also completly different because of the seat belt set up.
Old Sep 29, 2006 | 06:42 PM
cdoyle's Avatar
forgot about the Ttop bag, but I can make that work.
What is the difference with the door sills? I think the ones I'm going to go look at are from an 87.
Did they change how the seat belts are attached to the floor?
Oh, and I think I may have found someone locally who has the lower dash parts I need. I have to go look at them first. just wanted to let you know.
thanks again
chris.
Old Sep 29, 2006 | 06:47 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The sills will bolt up, but if you look at how your seatbelts are attached versus the 87, there will be a big open space. I think your belts are attached with a open round metal piece instead of the plastic base, I could be wrong though. (it may be 82-83 only, I forgot)
Old Sep 29, 2006 | 11:40 PM
cdoyle's Avatar
Mine has the plastic base!
you have to open a little door on the back, to get to the torx bolt inside to remove it.
I'm glad that's the same, I was starting to get worried there!!
Old Sep 30, 2006 | 02:45 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
89-92 plastics have shoulder belts in the rear also. So they are different than the 82-88's
Old Sep 30, 2006 | 12:20 PM
cdoyle's Avatar
oh that's right, forgot about the rear seat belts.
I'll have to keep that in mind.
Just curious, how hard is it to add rear shoulder belts? I'm hoping to some day add 4th Gen seats to it.
Old Sep 30, 2006 | 12:29 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i guess it wouldnt be to bad if you can weld, theres brackets built into the car you'd need.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
MORREALE5
Sep 13, 2015 09:16 PM
redmaroz
Aug 16, 2015 11:40 PM
