AC CONTROL AND VACUM
Old Oct 13, 2006 | 12:03 PM
ROCITUP's Avatar
I DISCONECTED THE VACUM THAT I BELIEVE RUNS FROM THE INSIDE CONTROL PANEL WITH ALL THE DIFF. VACUM LINES TO THE MOTOR. HAS ANY ONE ELSE DONE THIS AND WHAT RESULTS DID YOU GUYS HAVE.......THANKS.
Old Oct 14, 2006 | 06:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
None of the "doors" in the AC/heating system would open or close and I assume the default would occur: air through the defrost setting only. Also, I'd think you'd have a vac leak that couldn't be good.
JamesC
Old Oct 26, 2006 | 07:53 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Does this happen when one changes the ac/heater control box (the one above the radio) ? I changed mine today from the Camaro model over to the Firebird one, and once reconnected etc, started the car, didn't have any air coming through the vents, just the defroster, even though I simply disconnected and reconnected the bundle of vac lines.
Old Oct 27, 2006 | 06:09 AM
JamesC's Avatar
You may have created a leak where the vac lines join the 'fingers,' or perhaps the new control head's switch is bad.
JamesC
Old Oct 27, 2006 | 06:46 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Yes it will default to the Defroster, Mine went bad and I ordered another one then when I pulled my unit out it was different the one they gave me only had 3 vaccume connections and mine had 5, so I just took and drilled out the center, and used a screw to pull it back together.
Old Oct 30, 2006 | 07:30 PM
soundmaster4023's Avatar
Car: 1985 camaro Z28 Iroc-Z
Engine: 305 , 5.0 v-8 you know....
Transmission: automatic.... ugh
Axle/Gears: lol somthing i havent learned yet..
grrrr
welll I got my car... not to long ago actually... but when I took the dash apart to Chang the heater core... the ac only blows air out of the defrost vents... any suggestions?
zach
Old Oct 31, 2006 | 06:00 AM
JamesC's Avatar
If the system functioned before and doesn't now, you apparently created a vac leak when you replaced the core. Stick an ear in that vicinty and listen for hissing. Might be a vac line or vac motor. Since this is a common problem with out cars, you might consider a search (you'll find a load of info).
JamesC
tmellott89
Oct 14, 2015 02:06 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
