Seat belt upgrade (not related to recall sticky)
Old Dec 21, 2006 | 08:34 AM
SR-71's Avatar
Car: '88 Formula
Engine: 406, CF heads, Comp 212/218, Rhoads
Transmission: WC T5, 0.61 option
Axle/Gears: 10-bolt 3.08, re-ground Auburn Posi
A while back, my driver's side shoulder belt would not lock or retract. I opened it up to find that the shaft for the belt spool had come loose from the side plate of the ratchet assembly, so the shaft was turning free.
I "fixed" it by welding it. However, the metals didn't like being welded, and though it stuck OK, I really don't trust it if I really need it.
I can pick up a replacement from the local U-Pull-It salvage. But since the plastic sleeves on the floor pieces are splitting and dying, I was wondering about an upgrade.
  • How are 4th-gen belts mounted? Are they still in the roof like our cars, or are they in the door or seat back?
  • Does any one know of a source of aftermarket belt systems, short of a 5-point harness?
Thanks.
Old Dec 21, 2006 | 03:12 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I believe 4th gen belts mount very similiar to the 1982 belts, with the retractor in the roof only. This is a popular swap, and I think there might be a tech article on it as well. I think you may have to change out your sill plates to the 82 style or you'll have huge holes from where the retractor mounted.
I have not done this swap myself, but many others have, perhaps somone who has done this mod can provide additional info.
edit: here is the tech article on 4th gen belts:
https://www.thirdgen.org/4thgenbelts
Old Dec 22, 2006 | 07:41 AM
SR-71's Avatar
Car: '88 Formula
Great! This is exactly what I wanted to know. I'll just hit up the salvage for a 4th-gen set of belts.
very much!
Old Feb 1, 2007 | 04:32 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Here is a pic of the 82 sill plate beside an 83 and up style.
Old Feb 2, 2007 | 12:23 PM
alloy's Avatar
Car: 87 IROC-Z28
Here is what the 4th gen belts look like with the 82 sill plate.
Old Feb 2, 2007 | 04:08 PM
alloy's Avatar
Car: 87 IROC-Z28
Double post-sorry
Old Feb 2, 2007 | 06:44 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Ya if only i can find some 82 sill plates now...ive had 4th gen belts but they will look ugly if i cant somehow fill the gap by the sill plate...
Old Feb 3, 2007 | 11:25 PM
alloy's Avatar
Car: 87 IROC-Z28
I found my set of sill plates on Craig's List for $20. Might give that a try.
I visit the local boneyards often, if I find another set I'll let you know.
Old Feb 4, 2007 | 11:26 PM
83Chevy__Camaro's Avatar
ive got an 83 and it has the same sill plate as the 82 style that your talking about, so i dunno where you got your information
Old Feb 5, 2007 | 12:09 AM
alloy's Avatar
Car: 87 IROC-Z28
The information came from here through searches I made. I've not seen and 83, but I found an 82 with the plates I needed.
If they are also on an 83, then so be it.
Old Feb 5, 2007 | 11:17 AM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
Does anyone know a place where I can find that style (82-83) of door sills new?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
rudolphschenker
Sep 4, 2015 02:41 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
