Snake head shift knob
Old Dec 24, 2006 | 09:53 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Snake head shift ****
Pulled this out of a 2001 GTP. Has anyone else used this? A test fit shows its about 1/4 inch away from the dash trim when in park. Which is far too close. There isint even enough room to het your hand back there
Old Dec 27, 2006 | 08:09 PM
Pocket's Avatar
Car: 91 Trans Am
Since you have an auto, the only important thing is that the cable is connected to the actual shifter. Where you move the shifter unit to makes no difference as long as the cable can reach.
That being said...
Id either slide the whole unit back or put spacers under the front of the shifter where it bolts to the chassis, angling it back some
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
