How do you remove the HVAC?
I want to replace my radio pod and I don't know how to remove the HVAC. Can someone help me please.
I FORGOT TO MENTION THAT I HAVE A 1985 TRANS AM
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
First,remove the 4 tork screws holding the radio/HVAC trim plate. Then you will see 3 screws holding the HVAC. Remove them. Then unplug the fan switch connector on the left side of the HVAC. Then unplug the cluster of vacumn tubes going to the vacumn actuator valve. To get the tubes off you must remove 2 round slip-on type clips holding the tubes to the acutuator. This can be done by prying with a screwdriver. Then you must remove the thermostat cable. There is a push in style clip that holds the cable end to the HVAC. It can be accessed from the top side of the HVAC. Squeeze it and the cable mount pulls out from the bottom of the HVAC. Then you can turn the HVAC and pull out the cable end. I may not give the best directions but I hope this helps. Badman
Just noticed you have a firebird. My directions may only apply to a Camaro.Badman
Car: Pair of 92 Z28s
same thing as a camaro, you got a few connectors, some vac lines with metal rivets. Then you have a button on the top of the controls that you need to slide to the side and pull the lever cable out. All very simple once your looking at it.
