Hatch pulldown in closed position,
Old Jan 11, 2007 | 11:36 AM
ejgator's Avatar
motor runs continuously. Battery on the charger now.
I searched the forum, but didn't find anything exactly like my situation. Can one of you opine as to the problem..? I see several complete pulldown assemblies on ebay with what seem to be reasonable prices... Would this be my best option?
I'm new to this forum, but I will appreciate any help. (Lon I see seems to be the guru in this area).
Thanks.
Old Jan 11, 2007 | 12:04 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Thanks.
The Motor is working, right. That means is getting it's voltage if you remove the voltage it has to turn off. I not sure exactly how this motor works but I would think there must be a microswitch somewhere to tell the motor the hatch is closed so shut down. If I had to guess I would think the microswitch or sensor thats decides the hatch is closed is defectived.
Old Jan 11, 2007 | 12:39 PM
85DropTopTA's Avatar
Car: 1985 Trans Am convertable
Axle/Gears: 3.42 LSD
does it actually pull your hatch down?
seems kind of odd it would pull your hatch down and then strain to keep moving. I think they work like our headlights. Just keep going untill the resistance builds high enough.
Kind of why the plastic gears strip out all the time.
If its freely turning without pulling the hatch down then those gears probably are stripped
Old Jan 11, 2007 | 12:54 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
at least its not stuck open like mine was I had to drive around with bungee cord holding it shut, you could always pull the fuse, and thatll stop it from running
Old Jan 11, 2007 | 01:44 PM
ejgator's Avatar
Thanks, all for the prompt response. I wasn't real clear on the first post, I guess. The hatch is not latched, but the pulldown is in the down position. The limit switch ( I have the assembly all apart now), I believe, relies on the bracket on the hatch to be in place to activate the contact that says "I'm down now".
Somehow, something must have tripped the switch contact that says "pull me down" without the hatch bracket in place.
So, I may have just an adjustment issue. However, since it's apart I would like to replace the plastic slides since a couple are broken. Are these available?
Old Jan 12, 2007 | 09:06 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
"Motor runs continuously" = broken gear nut. Download the instructions for the TDS 101170 aftermarket guides from the lower right-hand side of my web site under Documentation or the tech article I wrote that is on TGO. I have all the parts you'll need to rebuild your pull-down unit.
Lon Salgren
Top-Down Solutions
Old Jan 12, 2007 | 09:10 AM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
is there a way to bypass the stupid pull down somehow, mine you need to hold the button to open/close it, but its more of just a pain IMO, one more thing to go wrong
Old Jan 13, 2007 | 03:52 PM
ejgator's Avatar
Thanks, Lon. I had already ordered the guides and the gear nut from Hawkes Third Generation. Today before I saw your reply I had disassembled the unit and verified that both are worn out. The motor runs fine in both directions.
Gator
Old Jan 13, 2007 | 05:46 PM
lonsal's Avatar
That's fine. You'll find TDS made the guides you got from Hawkes.
Lon
db057
Apr 28, 2019 07:45 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
punkmaster98
Sep 30, 2015 11:01 AM
corey8084
Sep 17, 2015 02:56 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
