2 questions
Old Jan 12, 2007 | 04:59 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
2 questions
Can I move the steering column to the left or right any. Is there any way to adjust it this way? Mine is all the way to the right and I want to center it.
Secone question is that the passanger floorboard is moist. No puddle just moist. The fluid has no real smell to it and I can't get enough on my fingers to feel its texture.
Old Jan 12, 2007 | 05:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There are two bolts holding the steering column up underneath the dash. Loosen them and you've got maybe an inch of play from side to side to line up the column.
A wet passenger floor is usually a sign of a leaking heater core.
Old Jan 12, 2007 | 05:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
How much is that to replace?
Old Jan 12, 2007 | 05:20 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
If you have antifreeze in your radiator and the dampness in the passenger footwell has no smell, then it may be rain water leaking in through the heater box. From experience the heater core is a real pain to get to without removing the dash, so make sure it is that before you try swapping them!
Old Jan 12, 2007 | 07:51 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Any way I can stop the rain leak if it is that?
Old Jan 13, 2007 | 12:30 AM
Pocket's Avatar
Car: 91 Trans Am
#1 find where its leaking
#2 fix the leak
Old Jan 13, 2007 | 08:27 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Ya ok I had that one comming. I mean if other people have had this problem then where did it come from.
Old Jan 13, 2007 | 04:11 PM
Pocket's Avatar
Car: 91 Trans Am
Common spots and fixes
*Front corner of the t-top* - adjust t-top and window, possible that rubber seal is beyond fixing
Rear corner of the t-top
Rusted hole under the center section of t-tops - General rust repair
Rust hole under the seal of the windshield - Have to pull out the surrounding rubber and check for rust, sometimes is under the paint and hasnt shown up yet
Broken seal on the HVAC/firewall - Usually when someone has removed the HAVAC unit or part of it and damaged the rubber/foam during reinstallation
Rusted out area under the blower - Peel back the pass floorboard carpet and look, this usually from leaves and dirt trapped under the blower
Rusted out area under the brake booster
Rear hatch water channels with a broken seal - Silicone fix this
Or a broken heater core
Good luck, leaks are always a pain to track down
Old Jan 13, 2007 | 04:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I don't thinkd that it is the heater core because the heat still blows nice and strong.
Old Jan 13, 2007 | 04:40 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
The heat would still blow nice and strong even if it was leaking, if the core were clogged it would not blow heat at all though. Could still be your heater core, it never hurts to check.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
