F-IN heater!!
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
F-IN heater!!
i know its been really cold outside here..around 0 for the most part..and my heater gets warm...but not HOT by any means..whats up with it?
Car: 87 Camaro IROC
your heater core is regulated by engine coolant temp. does your engine warm up to normal opperating tempurature?
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Ironic, I've always had the opposite. Mine always feels like a furnace once its fully on...
Could be a bad heater control valve. Maybe the vacuum line that opens/closes the door inside the vents for the heater has something wrong with it but thats highly unlikely.
The heater core might be slightly or completely clogged. Take the heater hoses off but leave them connected to the heater core. Then try to flush the heater core out, with a garden hose or something. A good flush worked on one of my friend's car with his heater core problem.
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
My heater is really weak as well. I also know my heater core has a pin-hole or two. I just always assumed the pressure loss because of the hole was affecting mine.
https://www.thirdgen.org/forums/cool...+control+valve
