Please help.
Old Jan 18, 2007 | 01:14 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
Please help.
I've used the search function and I still can't figure out how to get the window crank off my door. I read the tech article for removing door panels, but that's for automatic windows. Can someone give me a clue on how to do this. I know there is a tool you can buy, but I don't want to get it just to replace these two door panels and have it collect dust.
Old Jan 18, 2007 | 01:24 PM
Firebat's Avatar
I'm taking one off today, hopefully anyway. The tool ran under $20 i think. Could always ask around and see if someone else has one.
Edit: The tool costs less than $7 at O'Reilly's.
Old Jan 18, 2007 | 01:33 PM
84 trans am's Avatar
Car: 89 RS
Engine: 2.8
Transmission: t5
I just used a pair of needle nose pliers. push in on the panel and you can get in there with them and pop the retainer right out.
Old Jan 18, 2007 | 02:11 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Does anyone have a pic of what this piece looks like, because I can't see it. I heard it's supposed to look sort of like a horseshoe shape, but I'm not seeing it at all.
EDIT: Nevermind, I've found it.
Old Jan 18, 2007 | 04:53 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Ok, now I've run into a new problem. I want to replace the black rubber part that runs along the top of the door and comes to the mirror, that sort of looks like an arrow. I can only get to about 2 of the screws that hold that on, but my window doesn't roll down far enough to get to the other screws. Can someone give me a suggestion? Is there any way I can make my window roll down any farther? I really don't want to have to remove the window.
Old Jan 18, 2007 | 05:25 PM
Car: 89 RS
Engine: 2.8
Transmission: t5
I ran into that same prob. the other day. I havent gotten it figured out yet but i think the window is going to have to come out. If i find another way i will let you know.
Old Jan 18, 2007 | 06:32 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Thanks man. If I figure anything out I'll be sure to post it too.
Old Jan 22, 2007 | 03:10 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Doesn't anyone know how to get the weather strippin off the door that runs along the top without removing the window??
Old Jan 22, 2007 | 03:28 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
The horizontal weather strip that runs along the outer edge of the window / door?
Remove the inside door panel. Loosen the window adjusters that have the anti rattle felts on them. Use a wedge to push the window inward, you should have just enough room to access the screws that hold the weather stip in. It's tight! Expect to drop the screws. Installation takes time. The new strip edge needs to be molded to fit the door. Put it back reverse of how you took it apart.
Old Jan 22, 2007 | 11:41 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Thanks for the tip. I'll give it a try.
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
