Upgrade to power drivers seat
Old Jan 27, 2007 | 04:51 PM
libolt's Avatar
Car: 1991 Trans Am
I'm looking at possibly upgrading the driver side seat in my 1991 Trans Am from the Manual Track to a power track. To do the conversion, do I just need the powr track like this:
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Also the appropriate wiring to the fuse block, or is it more involved than that?
Thanks,
Mike
Old Jan 28, 2007 | 12:05 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Thats got most everything you need if you are going to keep the same seat. It should be wired directly to a hot power source as the seat should still be able to move with the vehicle off. Im not sure how tall you are, but I am 6' and it wouldn't hurt the power seat at all if it would move back another inch or so. Just something to consider.
Old Jan 28, 2007 | 12:59 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
just make sure it is properly fused and you should be good to go.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
