Need Help Deciding 2!
Old Feb 18, 2007 | 11:56 AM
blackwrestler34's Avatar
Car: 88 Pontiac Trans AM
what can i do that can spice the third gen dash up a little more...wha kind of paint would be used for plastic parts and will not chip?
Old Feb 18, 2007 | 12:05 PM
Chad Oliver's Avatar
Car: 67 ss 89 rs
Engine: 327 350tbi
Transmission: 5speed
maybe some fast and the furious stickers! mmmmmmmmmmmm spicy
Old Feb 19, 2007 | 12:59 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
I know that there are spray's out there that will work for this, you might try doing an indepth Google search for products that adhere well to plastic.
Just be careful with your choice of color if you decide to do this. Lots of people have gone and tried something along these lines, and most have failed to make it look relatively pleasing. You might try doing some additional research on TGO before committing yourself to the project. Paint is very hard to undo.
Old Feb 19, 2007 | 02:03 PM
Car: 67 ss 89 rs
Engine: 327 350tbi
there is no paint in the world that will not chip or scratch. I have repainted interior parts before using SEM brand paint for flexible plastics. I have done it primering the part first, and done it without the primer, I have even tried the clear coating. Places like yearone and classic industries sells interior paint that will come close to matching the stock colors but they are usually a shade or two off. Krylon makes paint for plastics. If you do decide to use paint, remember to remove all items from the interior. Use a paint prep degreaser/cleaner, a tack cloth and don't touch the side you are going to paint because you'll end up with finger marks where the paint didn't stick. Practice on cardboard first. Use several light coats.
Check out the LED light bulb mod, it's pretty tasteful when done properly and you don't have to worry about getting the runs from the spicy interior paint.
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
