question
Old Feb 20, 2007 | 06:40 PM
DillonRager's Avatar
question
i have the 87 LT model camaro and i dont have a tach just a huge fuel guage but is the wiring for the tach behind there if i were to get one also would my speedo be mechanical or electric how can i tell? thanks
Old Feb 21, 2007 | 10:31 AM
Old Feb 21, 2007 | 12:39 PM
irocyourpants's Avatar
Car: iroc
do a quick search but im almost positive your speedometer is mechanical
You can tell by the year the car was
Electric started either 89 or 90 I believe
Old Feb 21, 2007 | 01:36 PM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
Your speedometer is mechanical. Electical on camaros came in 1990 when they changed the dash all together. And my 84 s/c had the huge fuel guage and i got the 140 mph iroc dash with the tach and it works fine.
Old Feb 21, 2007 | 03:18 PM
hey thanks guys
sickcuban, was the wiring for the tach already there?
thanks again
Old Feb 24, 2007 | 12:18 PM
Sickcuban's Avatar
Car: 1984 Camaro
Axle/Gears: 4.10
yes you see, there are 2 like clips in the back of the Guage panel. Each one has wiring going to them. The tach wiring is already hooked up.
To simplify everything i said, any swap of guages will automatically work, unless it is a 90-92 guage cluster.
And a little more FYI, if u swap like an 80 mph guage for 140 guage, it works fine. The only thing that you might have to change like i did was the sending switches since i had the tri-warning lights for like temp and oil, if u already have needles, it will be a direct swap.
Oh and no prob
Old Feb 24, 2007 | 02:35 PM
thanks alot that answers all my questions
nice car by the way love to see fellow 3rdgenners without ground fx
Last edited by DillonRager; Feb 24, 2007 at 02:35 PM. Reason: Automerged Doublepost
Old Feb 24, 2007 | 02:52 PM
Sickcuban's Avatar
Car: 1984 Camaro
Axle/Gears: 4.10
yea no prob. If u need any more questions about anything let me know. most of our "base models" run along the same page and i pretty much changed everything so let me know.
Oh and yea i was debating bout changing to the 84 Z28 style but i was like, this is like 300 lbs lighter so ill keep it.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
