Complete replacement of gauges
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Most of my gauges are screwy, and I know the factory tach is inaccurate at high rpms. Is there anywhere to get a complete aftermarket replacement of the whole board using the factory positions? I dont really want a bunch of gauges all over the car. (Already have boost, a/f ratio, and knock sensor)
Car: 91 rs
Axle/Gears: 3.50 9"
Nevermind, I was searching using the wrong words. Looks like for what I want I'll have to do it completely custom. Dont want any of that digital crap.
Car: '83 Camaro
Hawks or FBody motorsports sell autometer gauge clusters for ~$500 I think. I installed a LS1 and installed all autometer gauges myself without one of their faceplates.
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Car: '83 Camaro
I used a 2 inch hole saw for the small gauges and did the big 5" gauge holes by hand with a dremel. Behind the gauges is a mess right now but I have plans to make a harness to make it easier to take them in and out. Supreme Member
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Be sure your sitting before you look at this:
http://www.hawksthirdgenparts.com/in...ROD&ProdID=604
Seems rather expensive. haha
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Reason for price is installation of guages and some of those guages are over $80 a piece. So that could be why the price is what it is...plus they have to make profit so.. $800 for all new lightweight guages for me...Hmm Good. Better than guages everywhere and wires all about.
Car: 89' IROC-Z
Engine: LO3
Car: '83 Camaro
With aftermarket gauges? Let's see some receipts
For the price, this is very reasonable... If I would have seen this before I started on mine I would have bought it.
http://www.hawksthirdgenparts.com/in...ROD&ProdID=609
Car: '83 Camaro
Car: '83 Camaro
Car: 1992 Camaro RS
Yes 3 3/8ths, in the bottom left is my nitrous gauge, air/fuel ratio gauge bottom right. then I have trans temp, water temp & oil pressure on the pillar. I went a little crazy on them but everyone seems to like the setup.
Car: 91 rs
Axle/Gears: 3.50 9"
Car: '83 Camaro
Terrell351
Jun 13, 2021 01:13 PM
Nah man I don't care, wasn't really much thought into it.
