heater vacuum lines
Old Mar 17, 2007 | 08:08 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
heater vacuum lines
i looked in the search and found some good threads on vacuum lines to the heater.my question is when they put my new engine in they did'nt connect the two hard vacuum lines.for the heater to work right. i have a 88 iroc and went from tpi to carb i guess it had a heater control valve but it does'nt anymore.do i need one?one line is straight and the other has a elbow since i no longer have a plenum where can i hook these to.
Old Mar 17, 2007 | 01:19 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hum ive never seen two vac lines to the heater control
always only one through the firewall with the wiring harnessand it connects to the intake manifold
good luck
Old Mar 18, 2007 | 09:12 AM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
hvac
good luck
from what i was told in 87 they started with heater control valve so maybe there is more lines.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
