help takin door off for motor
Old Mar 23, 2007 | 03:08 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
idk if this is a way overasked question, but how do u get the handle part off the door?? i got a 91 gta and i cant figure it out. i think im lookin too hard. i need to take it off so that i ca change the motor out. are there any other tricks i need to kno bout? if so lemme kno plz. thanx
Old Mar 23, 2007 | 05:49 PM
Steve86TA's Avatar
Car: To many to list
Re: help takin door off for motor
The outside handle has 2 cut nuts/body nuts that hold it on and the inside handle has rivets that hold it on.But you dont have to take the handle off to change the window motor
Old Mar 23, 2007 | 11:55 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
can u help me mke it as simple as possible. im gonna do it tom. prolly. f u have pics lemme kno. i kno mostly wat im doin just wonderin if i have to take off whole door panel.
Old Mar 24, 2007 | 08:12 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
First off, learn to spell and form a decent sentence.
Secondly, what are you talking about? According to your post, it seems like you want to take the handle off of the door so you can pull the motor out of the car.
Are you trying to change the window motor? If so, what "handle" are you trying to take off? And why? Are you going from manual to power windows (THATS fun .... sarcasm ..)?
Please clarify.
Last edited by Slepewesel; Mar 24, 2007 at 08:13 PM. Reason: Sounded more harsh the first time ...
Old Mar 25, 2007 | 05:12 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
im sorry i didnt know i needed to be an english major to go on message boards. i just need to change the window motor out because it is bad. i just was wondering how much of the door should i take off? thats all and i was wondering if anyone has done this so i may see a picture of it. thanx
Old Mar 25, 2007 | 05:46 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Ok, first, get a book. Preferably a factory service manual ...
www.helminc.com
If you cant get one of those, a Haynes PLUS a Chiltons will suffice.
Second, the only thing you need to remove is the door panel and possibly the plastic weather guard, if its still there, to gain access to the window motor.
The window motor is basically a pain in the ***. I'm in the process of swapping from manual windows to power windows. While I had the regulators out, I replaced the window motors. You can do it this way, but be careful of the regulator coming loose when you drill out the rivets holding the motor on, it is spring loaded.
See this link for removal of regulator assembly ...
http://www.p71interceptor.com/thirdgen/powerwindows/
Probably easier to do, is leave the regulator in and just drill out the rivets for the motor if you can get to them. Been a while since I worked on one IN the door, so i dont remember. I'll get you some pics shortly of the stuff I'm talkin about ...
Old Mar 25, 2007 | 06:59 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Ok, here is a pic of the regulator assembly and the motor attached to it. The regulator is the thing with the huge gear and the "arms" with the wheels that slide into the tracks on the inside of the door shell and to the window.
Pic of the spring putting tension on the whole thing. If you are looking at the inside of the door, this is facing OUTSIDE.
And the window motor. Originally there were rivets where the bolts are now. My rivet gun is a POS so, I used bolts.
Old Sep 25, 2011 | 02:24 AM
blakecharles's Avatar
sorry to bring this back from the dead...
how did u get the regulator out of the door??? Mine is stuck.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
