New Door Panels
Old Mar 30, 2007 | 02:02 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
New Door Panels
When I pulled off the door panels to fix my door handles they pretty much fell apart. Where can I get the actual board piece? I dont mean it cut out, i can do that but just a sheet of it. And where would I be able to get the carpet and leather materials? Im not buying new panels or having someone else to do it I just dont have the money.
Old Mar 30, 2007 | 03:12 PM
j dezzy's Avatar
Car: 87 TA
Re: New Door Panels
Use masonite for the backing. it'll last a lot longer, and it's good and sturdy. Not sure about the rest. Is there anything left of the skin that can be salvaged?
Old Mar 30, 2007 | 03:18 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: New Door Panels
Yes, The carpet is grey and I want to keep it, I wanted to replace the "stripped" on the top half w/ some perferated(sp) black vinyl or leather. Ill post a pic later.
Old Mar 30, 2007 | 03:19 PM
j dezzy's Avatar
Car: 87 TA
Re: New Door Panels
Do you plan on making the upper part molded like the stock? Or are you just going flat?
Old Mar 30, 2007 | 03:35 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: New Door Panels
I think I know waht your talking about like the vertical rectangles? Well mine came flat I wish it was molded it would look better, ill go take a pic.
Old Mar 30, 2007 | 03:44 PM
j dezzy's Avatar
Car: 87 TA
Re: New Door Panels
Just checked out your cardomain, I thought around here was the only place with an F-body for their DARE cars. lol. There are 3 running around here that people have bought and never repainted. If you've got the flat pannels then it shouldn't be too hard to remake something that looks stock.
Old Mar 30, 2007 | 03:52 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: New Door Panels
Haha yeah, I want to replace the top part of the carpet with some perferated vinyl to make it look better.
Old Mar 30, 2007 | 03:53 PM
j dezzy's Avatar
Car: 87 TA
Re: New Door Panels
Sounds good. post some pictures when you get around to doing it.
Old Mar 30, 2007 | 04:00 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: New Door Panels
There^ will probably replace the striped part with some black vinyl. how would I go about replacing the strip that seperates the two materials in the middle of the panel?
Old Mar 30, 2007 | 04:27 PM
j dezzy's Avatar
Car: 87 TA
Re: New Door Panels
You can find those strips at any auto paint store. My local store carries about 12 or so different kinds. They're inexpensive too.
Old Mar 30, 2007 | 04:51 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: New Door Panels
Okay cool Thanks
Old Apr 6, 2007 | 12:48 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Re: New Door Panels
1) you should be able to find 1/8 inch panel board at Lowes or Home Depot.
2) use closed cell foam for the padding(1/4 inch is good) but remember to go over it first with sandpaper(on both sides!) to remove a little of the coating otherwise it will lift. You can also, once it is attached but before you go over it with a lot of pressure to secure it perminently, cut out some accent panels or strips or grooves that you can then force the leather or suede into- very trick!
3) use ultraleather or ultrasuede(you can get it from Joanne's Fabric or on the internet)- it stretches more than vinyl and is easier to work with. Looks better too...
4) use the 3M upholstery glue(the heavy duty one)
5) cut the carpet for the bottom to fit and then take it to an upholstery shop or tailor and have them hem a strip of the ultraleather around the edge- then glue it in place.
Hope this little tutorial helped!
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
