gas gage stuck
Old Mar 30, 2007 | 07:15 PM
russianneckred's Avatar
Car: 91 RS from coast to coast!
gas gage stuck
Hey folks,
Hey I got a Gas gage which gets stuck in the middle, Like it goes from full to half fool and just stays there, any tips? should I be taking my dash board out
(I have a parts car). Or should I be looking into the gas tank?
Opps forgot, its a 92 V6 Firebird RS.
Last edited by russianneckred; Mar 30, 2007 at 07:16 PM. Reason: Automerged Doublepost
Old Mar 31, 2007 | 09:12 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: gas gage stuck
Originally Posted by russianneckred
Hey folks,
gas tank
Old Apr 2, 2007 | 08:47 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: gas gage stuck
Classic bad GM sending unit float symptoms...your problem lies in the tank. Every GM car I have ever owned has done this. Either the plastic gears get stripped and it stays way past the mark, or the gears get gummed up and it sits somewhere in the middle.
Old Apr 2, 2007 | 09:10 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: gas gage stuck
Hey folks,
I think it is in the tank also. But, you need to go back to school.
gage= gauge
fool=full
Old Apr 3, 2007 | 01:13 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Re: gas gage stuck
Well, I replaced the gauge cluster in my car yesterday, and I yanked it out today to replace the fuel and voltage gauge. I've done gauge swaping in couple of third gens and to tell you the truth, every damn gauge that I used had a mind of its own. The common problem I found with the gas gauge is that the screws in the back (that hold the gauge in as well as provide contact for the gauge itself) tend to get a bit loose throughout the years. We are talking loose enough to where a "strategically placed" bump would create "ghost" problems many people exprience.
I've seen gauges drop as much as quarter of a tank when I was braking. I saw them stay in one place for a while, and than go low like you just wasted a bunch of gas. Both of these were caused by the screwes being loose (just loose enough). Its worth a shot.
If your gauge used to work and now it started doing this I would check the back of the cluster. Its also good maintenance thing to do. Take the cluster out and tighten the screws and the bulbs.
I've got that down to a science. It takes me 15min. to take out the firerbird cluster out the right way. To change gauges it takes no more than 5 minutes. It really should be no probelm for you to check this. If you wanna know more shoot me a PM and I can explain it in detail. That way you don't brake any parts.
Hope the problem is simple.
Old Apr 5, 2007 | 07:13 PM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
Re: gas gage stuck
yea mine is stuck too but I have a camaro, which is totally different from the birds. I have to check everything because the gauge works, but it pins itself to past full. I can take the cluster pieces off, and move the needle down but the power pushes itself back up. My dad (the mechanic) says it is prolly grounded out somewhere, but i have a feeling its in the tank...any one have an answer?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
ctoledo0834
Sep 18, 2015 04:16 PM
Glowsock
Sep 11, 2015 11:09 PM
Ian Irvine
Sep 4, 2015 08:08 AM
