What products do you recommend for dashpad repair?
Old Apr 3, 2007 | 01:07 AM
steve's Z28's Avatar
Hi. I've a 91 Z28 with a broken dashpad. Driver's side impact crack on the corner. Second crack is on the dashpad speaker and on the driver's side. What kind of products have any of you used to repair dashpads? I am posting a couple of photos with this post.
Attached Thumbnails What products do you recommend for dashpad repair?-dsc00220.jpg   What products do you recommend for dashpad repair?-dsc00221.jpg
Old Apr 3, 2007 | 01:11 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: What products do you recommend for dashpad repair?
I'm not exactly sure how this stuff works on a dash but I used this vinyl repair kit from AutoZone and a seat one time and it worked great, couldn't even tell that it had been repaired!
Old Apr 3, 2007 | 01:17 PM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
I havnt had any luck with Dash fixers. You can replace the top of your dash (the whole thig) for 80-100 bucks. Just check ebay for it. I had a really cracked one and found one at a junk yard, guy gave it to me for 20 bucks. mint condition.
Old Apr 5, 2007 | 10:41 AM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Ive had no luck with that repair stuff from walmart, probably same as autozone sells where you mix different colors to get the right color then heat it with a soldering iron. it looked okay for a few months, then it changed colors after being in the sunlight for a while. in the wintertime, the cracks got even wider so I gave up and got another dash pad
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
drumstixer
Sep 29, 2015 03:02 PM
ironbmt
Sep 27, 2015 06:00 AM
kitt23
Sep 26, 2015 07:48 PM
Dragonsys
Sep 25, 2015 03:51 PM
