Will a grant horn button fit an apc wheel?
-- Joe
-- Joe
Jim85IROC
close
Some of the APC wheels were the same as the grant wheels. Grant has a few different style horn buttons, and APC may have a couple different styles too, so it's hard to say yes or no. You've got to measure the hole and figure it out for your particular application. Buy the horn button from your local auto parts store so that you can just return it if it's not right.
Quote:
Hi Jim,Originally Posted by Jim85IROC
Some of the APC wheels were the same as the grant wheels. Grant has a few different style horn buttons, and APC may have a couple different styles too, so it's hard to say yes or no. You've got to measure the hole and figure it out for your particular application. Buy the horn button from your local auto parts store so that you can just return it if it's not right. The problem is the button I want to buy is one i've never seen before, and on ebay.. hrmm.. Guess I'll have to take the chance huh?.
-- Joe
Jim85IROC
close
Either that or get the part number and have your local store order it. If it's a current product, it should be on Grant's site.
Quote:
Hrmm. good point. I wonder if autozone will do a return on a VDP order for grant stuff.. the # is 5652.. Originally Posted by Jim85IROC
Either that or get the part number and have your local store order it. If it's a current product, it should be on Grant's site. Thanks Jim!
-- Joe
Jim85IROC
close
I'm sure that Advance Auto can get it for you, and if it didn't fit, you should be able to return it. But... that looks like their most common style horn button, which fits the majority of the grant wheels, and I'd suspect there's a very good chance that it'll fit your APC. However, you may want to take a look at 5870, 5871 or 5876. They're quite a bit nicer and will really transform the way the wheel looks. I bought a polished grant wheel with leather wrap for my Camaro, and it came with the chrome version of 5870. I swapped it for 5876, then took the chrome one and put it on my truck wheel, which had the plain horn like the one you're interested in. It really made that wheel go from "*******" to tasteful simply by upgrading that horn button to the bigger piece.
Quote:
Here is the wheel I bought. It' sat my shop now. The telescopic column basicly fell apart and I needed to replace the broken plastic parts.Originally Posted by Jim85IROC
I'm sure that Advance Auto can get it for you, and if it didn't fit, you should be able to return it. But... that looks like their most common style horn button, which fits the majority of the grant wheels, and I'd suspect there's a very good chance that it'll fit your APC. However, you may want to take a look at 5870, 5871 or 5876. They're quite a bit nicer and will really transform the way the wheel looks. I bought a polished grant wheel with leather wrap for my Camaro, and it came with the chrome version of 5870. I swapped it for 5876, then took the chrome one and put it on my truck wheel, which had the plain horn like the one you're interested in. It really made that wheel go from "*******" to tasteful simply by upgrading that horn button to the bigger piece. http://cgi.ebay.com/ebaymotors/ws/eB...5364&rd=1&rd=1
Whatcha think?
Jim85IROC
close
Typically I'd say I hate that wheel, but in a C4 that might look pretty good. However, scratch my previous comments about the horn buttons... they won't look good at all with that style wheel, unless they can cover that whole larger circle area. If not, I think your horn button will probably fit... that center section looks the same. If you pop that horn button out you should be able to bring it to an auto parts store and compare it with the standard button in their Grant steering wheels. If it's the same thing, then your Corvette one will work.
Quote:
I'll give that a try today. The C4 interior is pretty freaking ugly stock, anything to make it better will help..Originally Posted by Jim85IROC
Typically I'd say I hate that wheel, but in a C4 that might look pretty good. However, scratch my previous comments about the horn buttons... they won't look good at all with that style wheel, unless they can cover that whole larger circle area. If not, I think your horn button will probably fit... that center section looks the same. If you pop that horn button out you should be able to bring it to an auto parts store and compare it with the standard button in their Grant steering wheels. If it's the same thing, then your Corvette one will work. Thanks again!
-- Joe
Jim85IROC
close
Yeah, I'm really not a fan of the Atari interior, but I really like the 90+ interiors. The combination of a digital speedo with analog everything else like my 91 has is absolutely perfect to me.
Quote:
The Grant signature series button is smaller, and the GT series is larger.. wtf.Originally Posted by Jim85IROC
Yeah, I'm really not a fan of the Atari interior, but I really like the 90+ interiors. The combination of a digital speedo with analog everything else like my 91 has is absolutely perfect to me. For now I took apart the APC button and blacked out the center so it doesn't say "APC" in fried-rice format. The wheel doesn't look too bad in the car. The instructions to the mounting kit were not right though.
-- Joe
Jim85IROC
close
got pics?
Quote:
I actually removed the blacked out thing I did last night, downloaded a logo, printed it to scale, and put the horn button back together.Originally Posted by Jim85IROC
got pics?
http://members.cisdi.com/~anesthes/horn-button.jpg
I'm shooting you a PM. I need to ask you something non thirdgen related.
Thanks!
-- Joe
Jim85IROC
close
I meant pics of the wheel installed.
Quote:
I'll snap one tomorrow Originally Posted by Jim85IROC
-- Joe
Here is mine
That will fit a 5 hole APC wheel, buy a signature series button.
Jim85IROC
close
That wheel has the big chrome ring that I was talking about before. It makes that style wheel look much nicer than just sticking the horn button directly into the flat hole in the center of the wheel.
Quote:
Yeah, I had it off for a while... then I decided to use the ring, and I like it better now.Originally Posted by Jim85IROC
That wheel has the big chrome ring that I was talking about before. It makes that style wheel look much nicer than just sticking the horn button directly into the flat hole in the center of the wheel. Quote:
Well I woulda taken a pic today. But while sitting stopped on the highway, some guy fell asleep and plowed into me going about 50mph.. Originally Posted by Jim85IROC
That wheel has the big chrome ring that I was talking about before. It makes that style wheel look much nicer than just sticking the horn button directly into the flat hole in the center of the wheel. I'll try the picture again tomorrow if I make it (alive) to the shop.
-- Joe
Plowed into your vette or another car?
Either way I hope you are okay.
I'm ok, thank you!Originally Posted by nelapse
Plowed into your vette or another car?Either way I hope you are okay.
Plowed into my blazer. My trailer hitch destroyed this guys volvo, but it still caused some pretty decent damage to mine. Bringing it to the adjuster now to figure out how bad.
Friday the 13th man.. wtf..
-- Joe
