Check out my custom digital dash
Old Apr 10, 2007 | 10:53 AM
ck76239's Avatar
Car: 1982 z28, 2007 Silverado
Engine: 350 Chevy, 10-1 CR, Comp Cams 270h
Transmission: Th350,
With a newly rebuilt engine, trans, and rear end, I figured I'd spiff up my interior. I wanted to reset the mileage back to zero as well, to track the mileage on my new drivtrain....
I made the panel from some sheet aluminum. The gauges are Nordskog, I bought them from Summit... They make a drop in digital kit for our cars, but it doesn't have the gauges I wanted. It took me quite some time to build a wiring harness that I was comfortable with, but I'm pretty happy with what I wound up with...
Old Apr 10, 2007 | 11:16 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: Check out my custom digital dash
That looks really cool! I wouldn't mind getting their 90-92 Camaro gauges but I don't like that I'd have to cut up the factory harness to make them work. For $500 you'd think they could get their hands on some stock 110 gauges and mount the setup in there so it's plug-n-play.
Old Apr 10, 2007 | 12:34 PM
ck76239's Avatar
I didn't cut much of anyting in the factory harness... I etched some double sided circuit board material to make edge cards that fit into the factory harness slots. Then I soldered wires onto the other side of my homemade edge cards. If I need to pull the gauge panel oout, I simple disconnect the edge cards from the stock harness.
I had to run some new wires, as the digital speedo needs the two wire pulse system in lieu of the speedo cable... I also ran a sensor and wiring for trans temp...
Hardest part was using my stupid haney manual for the wiring schematic, it was awful...
Old Apr 11, 2007 | 01:38 PM
ghost64's Avatar
That a Z24 steering wheel? Looks pretty hot, like its supposed to be there almost..
Like the guages too, looks very slick in the dark there.
Old Apr 11, 2007 | 01:50 PM
ck76239's Avatar
Thanks!
The steering wheel in a Cavalier that was smashed in the boneyard....
I couldn't find a decent looking original steering wheel to replace my very worn original wheel, and i hate most aftermarket wheels, so this was the next best thing...
I do have a Z24 wheel, but it's 15" diameter, it looks too big and akward, the cavalier wheel was only 14" same as the original...
Ck76239
Old Apr 11, 2007 | 10:02 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I ran t-taps off the appropriate wires on the back side of the stock connectors, those wires run to a microprocessor box for my Dakota Digital gauge panel. If I were to put a stock panel back in, the connectors are still in place and functional. It cost a bit more than $500, but had to be made on site from my original gauge panel. Here's a close up installed in my 92 RS.
Old Apr 11, 2007 | 10:34 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I'm also thinking of getting a digital setup so the speedo dosen't need the cable? It just needs two wires to hook it up to work?
Old Apr 11, 2007 | 10:57 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
all of these digital dashes look sick omg im so jealous
Old Apr 11, 2007 | 11:12 PM
Al Hasse's Avatar
They come with their own speed sender (at least the Dakota Digital does) which converts cable to electronic, it plugs in the tranny where the cable would go. I didn't need to use it because my speedo was electronic in the first place and gets its signal from the ECM.
Old Apr 11, 2007 | 11:41 PM
IROCKERZ's Avatar
That is sick!!
Old Apr 12, 2007 | 11:28 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Not saying that these look bad or anything, because they dont....but I still think the GTA Digital Dash takes the cake
The only thing I dont like about the dashed above is that at night ALL I see are numbers, no nice lit up background behind them...
Old Apr 12, 2007 | 11:32 PM
TON*LOC's Avatar
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
you are breaking the speed limit sir !!!!!!!!!!
Old Apr 13, 2007 | 01:23 AM
Al Hasse's Avatar
It only looks that way. I took the picture while the car was on the rollers during a recent dyno test, looks better than 00 while at idle. That was all the stock V6 could do on that machine!! I hit the programmed speed limiter at 108 on a previous test on a different machine.
Not to hijack the thread, but ck76239 has a great looking setup too. Had I known about Nordskog before I got this setup, I might have gone that way. I like the circular bar graph with the yellow and red bands better than Dakota Digital's linear graph across the top. Looks great
Old Apr 14, 2007 | 03:44 AM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
still looks sick tho brother!
Old Apr 16, 2007 | 02:50 PM
ck76239's Avatar
Thanks Al, I was just thinking that about yours by the way... Had I known Dakota made a setup, I might have gone that route, because it looks nice!
ck76239
Old Apr 18, 2007 | 12:42 AM
Al Hasse's Avatar
Mine was a custom job because Dakota Digital doesn't stock the 91-92 style for the Camaro like they do the 82-90. Had to send in a complete panel for them to convert. Had I gone with Nordskog, they make a direct fit for the 91-92. I'm thinking about the same for my 89 also, but not until I get it a little more restored/modified.
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
