92 Cluster in a 86?
Old Apr 11, 2007 | 12:40 AM
A Seven X's Avatar
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
92 Cluster in a 86?
is there anyway possible to put a cluster from a 92 z28 into say an 86 irocZ??? since the 145 MPH cluster is soo hard to come by and i have a 92 cluster would it slide right in? or would it not work? my current speedo stopped moving. could it be just the cable???? speed sensor??? it worked for a little while i think the gear that is behind the actual guage is worn out and doesnt spin anymore.. anyone tried to do this or have done this?
Old Apr 11, 2007 | 05:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 92 Cluster in a 86?
If you swap the entire dash from 92 to 86.
No. Aside from fitment issues, the 92 is electric, your 86 mechanical.
Yes.
JamesC
Old Apr 11, 2007 | 10:08 AM
A Seven X's Avatar
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
Old Apr 11, 2007 | 06:51 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
it is possible with a lot of work to fit the cluster in using the old dash. i know some one who did. I think his screen name here is something like 84zz4.
I did it the easy way and just swapped the whole dash.
As for the elctric thing, that's not a big deal. Just use a VSS from an electric speedo car, send it into a TBI buffer box, one goes to the speedometer, one to the ECM.
Old Apr 12, 2007 | 10:44 AM
cdoyle's Avatar
Just swap out the entire dash, it's much easier then trying to fit the newer style cluster into the older style dash.
I did the dash swap last summer, and it's pretty easy. Just get a dash that has the C-100 harness intact. Then get the schematics for both years, and if any pins on the C-100 need to be moved, just move them to match your 86 harness.
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
