4th gen console woes
Old Apr 23, 2007 | 09:01 AM
jkicak's Avatar
Car: 87 Formula 350
so sunday i got it in my head that it was going to be the day i would install my 4th gen console in my 87 formula..... after about 4 hours of work i was able to get the console in and it looks great but i pounded the tranny tunnel down too far and now the tranny is hitting under acceleration.... oh, the vibration....
so now i will need to get under the car and pound the tranny tunnel back up...
**please keep in mind if you are going to do this DO NOT pound the tunnel down too far**
Old Apr 23, 2007 | 09:27 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: 4th gen console woes
aww man im sorry that sux
Old Apr 23, 2007 | 11:18 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Pound the tunnel? I didn't have to pound down the tunnel when I installed my 4th Gen center console...
Old Apr 24, 2007 | 12:06 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Same here. I'd trim the console before I pounded my tunnel down.
Old Apr 24, 2007 | 01:19 AM
jkicak's Avatar
Car: 87 Formula 350
i bet you didn't install the AUTO top plate.... i installed the auto.. there is NO way in the world you can get it to fit unless you move the shifter down about 2 inches....
and you can't trim the console to get it to fit.. if you trim it you will only make it sit LOWER and then you would have to move the shifter down even more!
EDIT: i see you DID install the auto but you had to hack up your radio pod...... mine is installed with the radio pod in tact... once i get under the car and pound the tunnel back up a bit it won't hit and everything will be fine.
Old Apr 24, 2007 | 06:06 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Hasn't anyone tried a 4th gen shifter unit?
Old Apr 24, 2007 | 06:50 AM
HCR13's Avatar
Car: 1987 Trans Am
I agree that auto shifter plate is a bitch to install. I had to trim some of the plastic tabs under the shifter plate itself. I also decided to lift the center console about an inch to fit correctly. Let us know how it turns out. I would be interesting to have a flush auto plate. I have to fabricate some sort of radio pod since I did destroy the last. I also plan to get a z-gate shifter, so that should be fun
Old Apr 24, 2007 | 04:25 PM
superchevy72's Avatar
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
mine just went right in like it was made for the car. i did it with the dash also tho and i have a 5 speed.
Old Apr 24, 2007 | 04:34 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Just have to say ... love the avatar superchevy72.
Old Apr 24, 2007 | 04:51 PM
Engine: LB9
haha thanks
Old Jul 17, 2007 | 01:15 PM
ranone21's Avatar
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
I am starting a console swap very soon.... I have a 98-2002 trans am console to put into my 89 t/a.... I will let ya know how it turns out...
Old Jul 21, 2007 | 02:08 PM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
I tried it with my original 3rd gen shifter in place but figured it wouldn't work. I went back to the junk yard and got the 4th gen shifter and had to remove the spot-welded piece that the 3rd gen shifter bolted to and drill new holes. Worked like it was ment to be, but now that 3rd and 4th are gone it is time to install my t56. By the way I used a 97 dash and console, if that makes a difference. Lastly does anybody got the upper portion off a six speed console and looking for an auto upper (not tring to hijack your tread dude)?
Hawk312
Aug 22, 2017 08:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
