Center console
Old May 7, 2007 | 05:44 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Center console
The screws holders on my firebird broke and the radio housing is just sitting on hump. Can a camaro one peice console fit in there. Cant find one anywhere but have run across several camaro consoles.
Old May 8, 2007 | 11:36 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Center console
if you remove the entire firebird set up meaning center console and separete radio pod the camaro "should fit" but it wont look right because i'm not sure how well the camaro radio section will line up with the whole dash area. but the ac and radio and shifter and ebrake should slide and bolt right in.
if you have an entire afternoon to spare wouldnt hurt to find out
or what you could do....go to a hardware store and make your own brackets and re-bolt the radio pod to the dash or wherever it used to bolt into.
Old May 8, 2007 | 06:17 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Re: Center console
The '84 firebird had the same console as all the camaro's, and the dash is the same. So theoretically, it should just swap in nicely.
Old May 8, 2007 | 06:27 PM
iroc88lb9's Avatar
Re: Center console
wrong. camaro console wont bolt in to an 82-84 firebird...brackets are off,looks similiar...mounts differently.
he has an 87....they are not compatible.... id just try locating another bird console...there easy to find and pretty cheap,or you could go the 4th gen route...and geta cupholder while your at it.
Ed1LE
Sep 30, 2018 09:14 AM
Lbibb
May 5, 2016 12:00 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
