Headlight knob, and yes I searched :)
Old May 12, 2007 | 10:53 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Headlight ****, and yes I searched :)
So I read all about the **** and removing the cluster, and the little mushroom.. etc...
After I pulled the plastic piece off as far as I could, I unclipped the switch for the defog.
Now I can see the little tiny button with the spring on it on the bottom of the plastic housing, but when I push it in my **** still doesn't come out.
It's an 88 IROC.
Do I gotta like push that little button like crazy hard in or something? I'm removing my cluster anyways to put some new blubs in...
Ideas?
Old May 13, 2007 | 02:19 AM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
Re: Headlight ****, and yes I searched :)
Have the **** all the way out, push the button, pull and wiggle the **** while pushing the button, releas button, pull again, push the button down and it should pop out.
its a pita x 100 but it will come out eventually, try several variations, put the **** into differnt postions, etc
good luck
-Carter
Old May 13, 2007 | 08:02 PM
Daishi's Avatar
Thanks bro.
Got it done.
Some advice for those who search and find this thread...
I took a butter knife and bent it up at about a 45' angle. Then pushed the button up as hard as I could. and pulled the **** out just twisting it left and right and literally with no warning it just popped right out of there...
So the ol' twist and jerk pulls off again.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
armac
Sep 29, 2015 07:06 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
codeysabatini
Sep 20, 2015 11:36 AM
armybyrd
Sep 16, 2015 07:00 AM
