Gauge Swap, Z28 from 82 Berlinetta
Old May 16, 2007 | 11:42 PM
geehumshriber's Avatar
I removed the front dash cover, the two screws in the bottom right section, but it still resists when I try to pull it out. Are there any other measures I have to take? I'll probably have to take off my steering wheel, but I still have a lot of room to somewhat remove the gauge section. What do I have to do to get rid of this resistance?!?
G
Old May 17, 2007 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gauge Swap, Z28 from 82 Berlinetta
I'm unclear about which cluster you're discussing and/or the year(s). The Z28 through 89 would have a speedo cable that must be released before the cluster will pop out. Furthermore, isn't the Berly digital?
JamesC
Old May 17, 2007 | 06:32 PM
I have an 82 Berlinetta Cluster. I'm putting in a late 80's Z28 cluster. How do I pop off the spedo cable? I know there's one on the cluster I'll be putting in. Does the dash require coming out?
Old May 18, 2007 | 05:13 AM
JamesC's Avatar
The following link will provide that answer (as well as give you some other ideas):
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
