Lighting it up blue.
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Im going to try an experiment and need some help.
What i plan on doing is going black and blue with my car. Its all black its an 89 rs. And on the int im going to go blue. Lighting that is. I want to make it so my dash lights up blue. And then i don't want neon tubes but i want to get like the feet area to glow blue but somewhat dim. Not bright but i want to turn it on and in side see it.
So the question is can any one give me like a guide kind of thing on how to go about this?
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Re: Lighting it up blue.
A good place to start would be to change your Dome light, your footwell lights, and your map light to blue bulbs... and while your dome lense is off, cover the white plastic around your bulb in that mirror like ducting tape.
I did mine like that today and BAM!! Insane amount of light.
I did the above with red bulbs and I absolutely love it, along with putting red LED bulbs in my HVAC and auto shifter lights.. What really sets my interior off is my Digital dash
About your feet area, go to the rice section of Autozone and buy some LED strips.
Engine: 305--
Axle/Gears: 2.73--
Were did you get your digital dash ash? and i think im going to completely take out the dome night. Right now my headliner is off and i wrapped the wires in electrical tape so its not as noticable but i might just completly take it out. who knows. Im going to have to hit up autozone soon though.
Ill post some pix of my set up later tonight for you too see. (no time now, late for work...again)
quisterio, got any pix of your dome light??
Engine: 305--
Axle/Gears: 2.73--
Radio shack... Does it have cheaper LED's? im thinking i might just go buy a few and rig something up my self just to learn about them a ittle bit and then once i can figure it out ill go in and actualy put in decent LEDS and lighting it up and things.
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Can I get more information on the bulb you used for your dome light? Where did you get it? Whats the technical name for it? (searched for what you called it, with no results)
http://www.superbrightleds.com/festoon.html
"44 x 10 mm Festoon base with 9 LEDs"
-that is the correct size for our dome lights.
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
crappy pic quality BUT...
Last edited by 1988CamaroSC; May 22, 2007 at 08:00 PM. Reason: Automerged Doublepost
As for lighting up the floorboards, I made a write up a while ago.
https://www.thirdgen.org/forums/auto...nder-10-a.html
Pretty easy, same method applies for any types of lights.
Car: 1992 Firebird
Engine: 3.1L V6
quick question, with the dome light, does the led dome lightbulb come with the hooks required, or do I need to modify something?
Hooks?? I know there are hook kind in the hatch (LED wont work unless you solder/modify hooks to them) but the dome you just pop/slide in. Unless you got something diff setup???
Car: 1992 Firebird
Engine: 3.1L V6
Though looking at it, it looks like who ever had the car before more (haven't had to change this bulb in the 3 years I've owned the car) just put a hooked bulb in there. It should just slide in then correct?
Little OT: You see the peg hanging down used to hold the dome light up there? Im missing one of the nuts. Any idea where to get one? If they are at the local autoparts store, wtf are they called bc last time I told them what its for, they were like huh?
-as for theose little "nuts", i know I have seen them in the help section of pep boys and western auto, dk what they are called, but not hard to find, just try another parts store....clueless people workin there nowadays i tell ya.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
OK, I'm having a little bit of trouble on the wiring. I have the lights in the foot well and I have the switch under my vents to light up the center console. My only problem is I don't know which wires to connect to where. I have the ground wires already grounded on the lights and I've run the hot wire from the pass. side behind the radio pod and spliced it into the driver side light. but where do I go from there? I know i have to ground the switch as well, but there are 3 prongs on it. one says "earth," another labeled "supply," and the last "load." And as for getting power for all this I can't figure out which wires have constant power under the dash.
Engine: LB9, LB9
Alright, I've finally finished wiring everything and it is all done. However, now I have a new problem. I keep blowing fuses. It's the fuse that is for the stereo, interior lights and door locks. it's a 20 watt fuse. The first time it blew I thought that I should just replace it with a 25 watt fuse but that one still blew as soon as I turned the foot well lights off. should I keep upping the fuse wattage until it stops blowing or should I find a different power source. Right now it is spliced into the wire that leads to the driver side courtesy light. Any advice is much appreciated.
-Let us know if that fixed it.
MikkoV
Sep 9, 2015 04:25 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
